Undercoating Removal
I want to clean up the brackets for the fuel pump on my Vanagon.
The undercoating is asphaltic and hard - likely 1/4 century old. any good solvents? I'll use limonene ("orange oil") unless anyone tells me so & so is much better... |
I have used a heat gun and putty knife to remove under coating.
Oscillating Multifunction Power Tool w/ Variable Speed
Removes undercoating with ease from a 40 year old car. |
I would start with the least harsh method, and gradually work up to the method that works best.
I might try a very high pressure power washer with an adjustable pressure setting for example. |
thanks folks - but these are small pieces - 2 fuel pump brackets & they fit in a tin can
oh, well then fill said tin can with diesel, and let them soak?
liquid nitrogen and hammer and chisel.
| All times are GMT -8. The time now is 07:06 PM. |
