Dumb question on Nascar/Danica P
It`s probably a given that Patrick is 100lb lighter than Stewart, Newman, Waltrip and many others, Right? Does the team then get to run lighter or do they ballast up to a minimum weight?. Assuming they ballast, do they get to put it where they want i.e.
on the floor to lower C of G?. If so, is that why she was one of one who kept the car down on the yellow line for quicker time? We all know about the Penske Camaros being acid dipped to be able add the saved weight lower on the car, is this more of the same only not having to acid dip Patrick as she is already light enough. Thank you for looking., |
I'd say Smoke has more than 100lbs on Danica....;)
As far as ballast goes, World Challenge used to make them ballast the passenger seat area for minimum weight and penality weight. I believe Nascar makes the teams ballast the frame rails with something like tungsten to get to the minimum weight. |
If it's in the frame rails, it would certianly add to the cars better cornering IMO.
Anyway today the fast guys including Waltrip and other 500 specialists are turning times almost 200 mph, so maybe it's all changing anyway. Goin' to be a good race. (A good distraction while waiting for F1) |
Most racing is good racing: F1, supercross, motocross, AMA, Swampbuggys,etc. Nascar used to be better when the old guard was racing. Now it is more tame and corporate. Still good racing though.
Unless the rules changed from a couple years ago, the car is weighed with driver fully suited, remote cameras installed, X gallons of gas, full oil system or escentially ready to race.
In DW's book about the early days of NASCAR they used to use lead, fake radios and then switch them until one was dropped on an official, load the frame tubes with lead shot and pull a small cover after race start to dump the lead but they got caught when a driver was dumping the shot and had to go down pit road to miss an accident....... They started weighing the cars AFTER the race too, still do. Then Smokey caused them to start using templates with his "small sized" cars! |
Someone was suggesting that the results were manipulated so she'd get a different plate and thus make the pole. Possible and look at all the press she/NASCAR is getting. They have stopped talking about her new boyfriend as well.
At least at the Daytona and Talledega races (restrictor plate races), starting position means next to nothing. There are so many lead changes, that they only count them at the completeion of a lap, and there was a race within the last couple years that the lead changed 70 times in 200 laps.
They said the same thing regarding her weight advantage when she ran well at Indy. She is fast and I'd like to see her win a few races. I would also like to see Jr win a few. Now Jr. and Danica as a couple.....Marketing Gold!
Those were the good ole days. |
As for weight, yeah, maybe a small advantage from ballast, but nothing I'd complain about. She's going to have a fast car with that Hendrick know-how no matter what. |
The size and perceived fitness levels of some NASCAR drivers is embarrassing. You don't like that your competitor weighs less than you? Try a diet and some exercise. And quit whining about getting beaten by a girl.
d. |
No one has ever complained about Mark Martin who is about 5'5" and 140 lbs, but the big guys like Tony Stewart, Ryan Newman, and Micheal Waltrip, are giving up close to 100 lbs to him.
I never heard complains of Danica's weight in NASCAR until now, and she's been racing in it for more than two years. There were definitely complaints in Indy, as Indy doesn't factor driver weight. |
| All times are GMT -8. The time now is 12:38 PM. |
