Does anyone here know automotive generators?
I have a 1963 Type 3 Karmann Ghia (aka T34), and I've rebuilt the engine as well as installed a rebuilt 6v generator. When the generator runs, it puts out a lot of sparks and light. It's putting out between 7v and 8v, and is not triggering the idiot light when running. I even tried it with the positive terminal disconnected, and it still sparked. I tried revving it up pretty high ; I don't have a tach, but it's a stock rebuild, so it couldn't rev too high and the sparking stopped... because one of the brushes popped off the commutator.
This is the second generator that's done this; the shop that sold me the rebuild sent me another one when I told them about the problem. Now that two of them have done it, I wonder if somehow it's my engine that's causing the issue, or if I got two bum generators in a row. What would cause this behavior? ![]() ![]()
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Is this a negative or positive ground car?
1990 Wanderlodge PT-40 75 911S Silver Anniversary 1952 MGTD 1983 Mercedes 300 TD 1969 Lincoln |
Friend of Warren
Did you polarize the generator?
Kurt V No more Porsches, but a revolving number of motorcycles. |
NYC
Carbon brushes often make sparks when breaking in on a freshly cut commutator. Perhaps there not installing them correctly You did say one of the brushes popped out. Try another re builder. You said every thing else was working fine.
My Dad's 60s vintage Sears drill does the same thing. However, I've never seen sparks like that on my 356c's gererator and they are the same bosch part....
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Great photography! That's not normal, but there isn't anything your engine could be doing to cause it. If you have a good 6 volt battery and a good voltage regulator it shouldn't do this. If it was only one generator that did this I would assume the brushes/commutator weren't making good contact, but it's hard to believe more than one generator would have this problem. I my guess is there is an issue with the voltage regulator. Voltage when running over 1000 rpm should be 6.9 or thereabouts, not 8.
. Last edited by wdfifteen; 02-23-2013 at 05:51 PM.. |
I'm with Bill
Great pics.
Does it make any noise or did it feel funny before you installed it? The color of the sparks almost looks like a bushing is grinding itself away
Electrical problems on a pick-up will do that to a guy- 1990C4S |
závodník 'X'
Rebuild from China.. what do you expect?
All fun aside, guessing you have to check the brush springs, brush alignment in the carrier. Also, does the armature have too much end play where it might knick a brush and throw it?
“When these fine people came to me with an offer to make four movies for them, I immediately said ‘yes’ for one reason and one reason only… Netflix rhymes with ‘wet chicks,'” Sandler said in a prepared statement. “Let the streaming begin!” - Adam Sandler |
How did ya "flash the feild" or polarize the generator ??? Good pics by the way.
Edgar 1984 Porsche 944 bone stock 1995 Mercedes E320 wagon 1970 Honda CB350 mint!!! Last edited by FLYGEEZER; 02-23-2013 at 06:43 PM.. |
Detached Member
Been a while with generators, and mostly Lucas. Check out the cut-in/cut-out voltages on the regulator magnetic coils for the field windings. With Lucas, you can turn some screws to change them. Not sure on German trash.
Hugh |
