usb3 memory sticks vs a SSD/HD
I have noticed usb3 memory sticks are cheaper then the same volume in a SSD/Hd esp in a 32g or 64 or even 128g a stick
like about 1/2 cost per G and the claim to run near the same max speeds sata3 = 6G , usb3 = 5G but max is not real world data transfer rates but MS in windoz 7 or earlier copy protection will not allow the OS to be run from a usb[1-2-3] memory stick w8 may work [but I donot like w8] do to the timing of the usb drivers loading do SSD's use the same or a different memory type then the usb3 sticks ? can linix or other O/S run off a memory stick is stead of a HD/SSD could several usb3 sticks be used to get more storage at the same time can a game or other program live on a memory stick [only plugged in when in use] with out taking up SSD/HD space ? is there a way to get all new data to only go on a memory stick and NOT on to a SSD/HD leaving only the O/S on the HD and never anything else ? I like the idea of useing different O/S's with a simple memory stick swap and having a totally eazy removable device with all my data on it are there any other type of non-usb memory sticks for firewire, thunderbolt, or sata3 ? that could allow a w7 boot from the stick ? |
linux, at least the version i am playing with, will boot from a USB thumb drive.
a short search seems to indicate that Win7 can be run from a thumb drive:
How to Install and Run Windows 7 from USB Flash Drive edit: and here: http://www.wikihow.com/Create-Bootable-Windows-7-Thumb-Drive this seems much simpler. |
thanks for the links
what version of linux are you using ? how is the load time vs a HD or SSD for linux from a usb3 |
AV Linux - Install...Create...
it comes pre-configured with SEVERAL audio and video software programs for creating/editing/producing. it is also a really nice version that runs well and fast. |
| All times are GMT -8. The time now is 05:23 AM. |
