Targa, Panamera Turbo
M.D. Holloway's Avatar
1985 Johnson 6hp gas oil mix ratio?
I'm thinking 40:1, any idea where I can find out?
Michael D. Holloway
https://5thorderindustry.com/
Old 05-26-2013, 09:52 PM
I've been told 50:1 for johnson's made after 1966
Old 05-26-2013, 10:55 PM
rfuerst911sc's Avatar
For my 1987 30 Johnson the factory originally stated 100:1 but apparently they had some engines go boom so 50:1 is now recommended. I would go 50:1 should work just fine.
Old 05-27-2013, 03:39 AM
You can not have too much oil. We have some race karts that like 16:1, My shifter ran best 30:1 and my Rotax practices @ 40:1 and races 50:1
Old 05-27-2013, 05:37 AM
Kantry Member
oldE's Avatar
I think I would caution on this one:
Too much oil raises the viscosity of the fuel mixture, lowering the flow rate through the jet and can lead to a lean mixture. Under load, you might not like the results.
Best
Les
Best
Les
Old 05-27-2013, 06:01 AM
mikesride's Avatar
1964 and up 50:1 is what I recall, somebody else said 66 and up......either way your a little after that!!!!!!
I've driven alot of crap to get here man!
Old 05-27-2013, 12:06 PM
Bill Douglas's Avatar
Best
Les
Thanks for the info Les. I have been running my chainsaw and weedeater at 35:1 instead of the recommended 50:1 thinking a little more oil is good for it.
Old 05-27-2013, 01:29 PM
mikesride's Avatar
Wait...... I thought you were lubemaster???????
Old 05-27-2013, 05:03 PM
I think you are correct but going 50:1 won't hurt. It may foul your plugs after a while but that's about it.
Old 05-27-2013, 06:33 PM
How do you think we learn? We ask and then the results present and get filed away for future reference
Michael D. Holloway
Old 05-27-2013, 08:38 PM
