Grip It & Rip It
edgemar's Avatar
Gasket and RTV advice
I replaced the vanos in my e36. I scraped off the paper gasket from the front the head with a razor blade and installed a new steel gasket with the new vanos. I didn't do a good enough job removing the old material and now it leaks
So lesson learned, I ordered some gasket remover and a plastic scraper and a new oem gasket.
RTV is not called for in the installation.....BUT....is it a good idea to lightly coat some RTV on gasket from the head to the gasket for extra insurance?
I'll really like to get some advice on sealing against leaks b/c I DO NOT want to do this job a 3rd time.
Thx!
82 911SC (sold)
Old 06-04-2013, 06:10 PM
Friend of Warren
The two mating surfaces have to be absolutely clean and smooth to prevent leaks, as you have discovered. Just do it right the second time around.
Kurt V
Old 06-04-2013, 06:36 PM
Grip It & Rip It
edgemar's Avatar
i'm a little worried i marred the surface with the blades. Will a few scratches in the aluminum cause a leak?
82 911SC (sold)
Old 06-04-2013, 06:45 PM
Super Moderator
cstreit's Avatar
A flexible gasket will be okay with shallower scratches. Persoanlly I like non hardening type sealants like Hylomar for these applications.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-04-2013, 06:49 PM
Or Curil-T.
Old 06-04-2013, 06:52 PM
Grip It & Rip It
edgemar's Avatar
is a steel gasket flexible? So i would put a real light coating of Curil or Hylomar on both sides of the gasket?
thx so much for the advice!
82 911SC (sold)
Old 06-04-2013, 07:05 PM
Misunderstood User
If the steel gasket is rubber coated or has a rubber foam, it does not need RTV.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 06-04-2013, 07:32 PM
Grip It & Rip It
edgemar's Avatar
i think it has a coating..
I think i'll clean the surfaces completely and try again.
82 911SC (sold)
Old 06-04-2013, 08:44 PM
I do these all the time.
Make sure the surfaces are really clean and coat the gaskets lightly with hylomar.
Also, don't forget a little dab of hylomar on the seams where it meet the cylinder head before you replace the valve cover.
Old 06-04-2013, 09:02 PM
Grip It & Rip It
edgemar's Avatar
cool I will get some hylomar....thanks for the info! Any other tips on sealing the valve cover?
82 911SC (sold)
Old 06-04-2013, 09:22 PM
Hell Belcho
Nostril Cheese's Avatar
Coming from a poster named edge - mar..
Old 06-04-2013, 10:55 PM
You do not have permissi
john70t's Avatar
Unstead of steel, I've used a brass scraper followed by a nylon roll-lock on a drill (sends chunks everywhere though). A little softer.
Old 06-05-2013, 06:24 AM
Grip It & Rip It
edgemar's Avatar
that is funny....
82 911SC (sold)
Old 06-05-2013, 07:12 AM
