-   -   cat door inside? (http://forums.pelicanparts.com/off-topic-discussions/753742-cat-door-inside.html)
id10t 06-02-2013 08:55 AM
cat door inside?
new addition to the house requires a litterbox. not ideal with a toddler around.
i want to add a cat door to one of our interior doors. is there a kit for a hollow core door? or do i need a whole new door as well ?
Rodsrsr 06-02-2013 09:19 AM
Home Depot sells several different kits that will work.
Zeke 06-02-2013 09:35 AM
Any cat door will work with a HC door. There is honeycomb bridging inside to hold the 2 skins together. Leave 2" at the bottom when you mark out the cut. If you have a raised panel molded door, it will be more difficult but it will still work.
dad911 06-02-2013 11:29 AM
Can you put it in the wall next to door? Easier/cheaper to patch sheetrock than replace the door later.
