-   -   Best Product for Flushing cooling system (http://forums.pelicanparts.com/off-topic-discussions/771069-best-product-flushing-cooling-system.html)
126coupe 09-12-2013 01:13 PM
My restored 1953 F 100 Pick up has been sitting for 3 years.
Lots of crap in the systemhttp://forums.pelicanparts.com/uploa...1379016794.jpg
Don Ro 09-12-2013 01:17 PM
White vinegar...which is just acid same as Prestone flush products.
I even used this diluted w/distilled water:
http://www.homedepot.com/p/Klean-Strip-1-gal-Phosphoric-Prep-and-Etch-GKPA30220/100406369
Nice rig...love the red.
GH85Carrera 09-12-2013 01:42 PM
I just do an oil change on the 911. No flush necessary. ;)
Tobra 09-12-2013 01:48 PM
There is some stuff the miata guys like, flush until clear with distilled water, put the stuff in, drive around, then flush and fill with your 50:50 mix or whatever. One guy suggested taking the top radiator hose off, running water into the top of the rad and just flushing it out. If you are really concerned about junk in there, maybe take the water pump off and flush it out through there.
Radiator shop will have rig to flush it out very efficiently.
Mrmerlin 09-12-2013 01:53 PM
is the coolant thats in the truck all rusty now?
What does it look like ?
If its not rusty, I would drain it then rinse in a few gallons of distilled water,
then fill will a 50/50 mix of your favorite Prestone coolant and Distilled water
If it is rusty there could be issues with whatever cleaner you choose as removing the crud may cause leaks that the crud was plugging
Might be a good idea to swap in a new thermostat and coolant cap
126coupe 09-12-2013 02:15 PM
Not rusty, just a lot of chunks of Calcium, radiator clogged and I removed both thermostats and replaced
126coupe 09-12-2013 02:17 PM
Anyone try this?http://forums.pelicanparts.com/uploa...1379020660.jpg
Don Ro 09-12-2013 02:25 PM
That's just watered-down this:
Klean-Strip 1 gal. Phosphoric Prep and Etch-GKPA30220 at The Home Depot
TimT 09-12-2013 02:32 PM
This product get a lot of positive chat on various truck forums
Fleetguard Restore
masraum 09-12-2013 02:50 PM
And an interesting note. I read a column in the current "Octane" magazine by Jay Leno. Apparently, he's had issues with coolant over the years, and has gone to a waterless coolant because it eliminates the corrosion that you get with coolant and has an increased boiling point. I guess he'd had problems with his vehicles due to water rusting and corroding things.
Based on a quick google search, he's using Evans Waterless Coolant.
Laneco 09-12-2013 03:02 PM
Make sure you turn the heater on when you are flushing it.
angela
Don Ro 09-12-2013 03:25 PM
"Evans Waterless Coolant"
Wonder about warranty w/my hot little turbo'd Abarth here in AZ.
RWebb 09-12-2013 03:56 PM
pics?
Don Ro 09-12-2013 04:00 PM
Since you asked: :D
http://forums.pelicanparts.com/uploa...1379026750.jpg
http://forums.pelicanparts.com/uploa...1379026784.jpg
http://forums.pelicanparts.com/uploa...1379026813.jpg
masraum 09-12-2013 04:01 PM
I have no idea, but an endorsement from Jay Leno is a good thing to me. The rust and crap that you run into when using water has always irritated me. I like the idea of a lifetime coolant that has a lower freezing point and a higher boiling point.
masraum 09-12-2013 04:02 PM
Originally Posted by Don Ro (Post 7653143)
Have you let Charlie Sheen drive it yet? ;)
Don Ro 09-12-2013 04:04 PM
"Have you let Charlie Sheen drive it yet?"
No comprende...
Don Ro 09-12-2013 04:06 PM
Have some friends who use "Evans Waterless Coolant" in their moto rads.
sketchers356 09-12-2013 04:07 PM
Higher boiling point is not the only issue for a good coolant. You also have to worry about heat conductivity. A high boiling point isnt going to do anything for you if the coolant is not moving the heat around properly.
RWebb 09-12-2013 05:36 PM
nice - it's a testa rossa!
