-   -   Torque Wrench Question (http://forums.pelicanparts.com/off-topic-discussions/772541-torque-wrench-question.html)
redstrosekNic 09-20-2013 01:47 PM
Hey guys,
I just bought a Precision Instruments split beam torque wrench. It seems like a decent tool, but there is play between the body of the wrench and the ratchet head. Is this normal? I've never had a split beam before, and have nothing to compare it to.
http://forums.pelicanparts.com/uploa...1379710051.jpg
Rick V 09-20-2013 01:52 PM
Some play is normal especially at the lower settings. Some of the chain tire shops have torque wrench testers there to help stave off lawsuits from inept tire guys. I am sure they would click it for you to see if you are close
redstrosekNic 09-20-2013 01:57 PM
Thanks Rick. The play is consistent, regardless of the setting. I am thinking it is normal, as there is a split beam running through the center of the tool. I'm out to the garage to see if the split beam moves around, causing the need for some play. I admit I have no idea how this type of torque wrench works.
Evans, Marv 09-20-2013 02:14 PM
Call the company.
redstrosekNic 09-20-2013 02:38 PM
I sent them an email, but figured you guys would be less likely to say "it's fine... Blah blah blah".
cashflyer 09-20-2013 02:53 PM
I buy only Precision Instruments. They are [one of] the best on the market.
A little bit of play where I have indicated is normal, and necessary for the split beams to function. If they were rigid, this would just be an expensive "breaker bar".
http://forums.pelicanparts.com/uploa...1379713947.jpg
redstrosekNic 09-20-2013 04:02 PM
^^^Exactly what I was concerned with. Thanks for clearing it up for me :)
