Replacing attached garage's door
am i correct in understanding that when I replace the door that joins attached garage to foyer, i have to use a fire rated door according to IRC codes? previous door was non fire rated from 1980's.
and as a landlord, how do i charge this to on former tenant's security deposit? full replacement cost with code update? or am i only allowed to charge him for what he broke, namely the non-firerated door?
Old 09-30-2013, 05:20 PM
NYC
Here in NY when i purchased my house the fire door was already installed. That was in 93. I would guess that's the standard code all around. I have a tenant and if here damaged my door I would probably ask him for a part of the payment either though a monthly payment or one time . He has been a good tenant.
Old 09-30-2013, 05:36 PM
The Unsettler
stomachmonkey's Avatar
Technically you should have replaced the door at your cost to comply with code whether it was broken or not?
So look at any contribution from the tenant as a bonus.
"I want my two dollars"
"Brandon Won"
Old 09-30-2013, 05:54 PM
A930Rocket's Avatar
I'd say that you need to replace it with a fire rated door. Get the dimensions off you old door and a new metal one can be made that you can just install the hinges and hang.
Old 09-30-2013, 05:56 PM
In most venues, you need a 20 minute door. Just about any solid core door will suffice. Some will want a plaque on the jamb of the door.
You need a closer on the door also.
Not expensive.
Just do it.
Old 09-30-2013, 06:48 PM
yea i plan on doing it. it's my old townhouse. when i moved in, i didn't have issue with it from city inspector. but yea now i'll replace it with firedoor.
Old 09-30-2013, 07:14 PM
