-   -   Can I get a little help on an Excel formula? (http://forums.pelicanparts.com/off-topic-discussions/774932-can-i-get-little-help-excel-formula.html)
lendaddy 10-04-2013 06:19 PM
Seems there must be a simpler way to do this than what I have so far. I don't want to do reference cells so it needs to be done in one cell.
Anyway... assume there is a column of cells A1 through A10. I simply want to SUM all the occurrences of "3" in those cells.
Then, to that total, add the product of another cell (lets call it A12). But here's the kicker, I only want to add the amount from A12 that exceeds 2.
So if the product of A12 =1 then I don't want to add anything to my new cell, but if it's 6 I want to add 4. That's what has me hung up, if I simply subtract 2 from that cell as static part of my equation I will often get negative numbers which will screw everything up.
Any help is appreciated, I'm just too tired tonight.
dtw 10-04-2013 06:29 PM
I don't have excel open so you might have to tweak syntax, but this should do it.
=SUMIF(A1:A10,"=3",A1:A10)+IF(A12>1,A12-2,0)
lendaddy 10-04-2013 06:34 PM
Excellent, looks like that works. Thanks!
jyl 10-04-2013 06:40 PM
I think the second term would be +max(A12-2,0)
So if A12 = 6, max (6-2,0) = max (4,0) = 4
If A12 = 1, max (1-2,0) = max (-1,0) = 0
lendaddy 10-04-2013 07:00 PM
I spoke too soon, looks like there is trouble in using SUMIF, I don't want to add all the "3s" together, rather count the number of occurrences.
As given if four of the cells contain that "3" it is totaling it to 12 when I want it to be 4. I tried changing it from SUMIF to COUNTIF but it doesn't like that...hmmm
dtw 10-04-2013 07:09 PM
Still no Excel in front of me, but play with COUNTIF. As a hack you could take the result of the SUMIF and divide by three, but it isn't the most elegant solution ;)
lendaddy 10-04-2013 07:10 PM
No sweat I got it, here was the solution (using the actual cells):
=COUNTIF(F4:AF42,2)+IF(F43>1,F43-2,0)
I sincerely appreciate the help, I normally have no problem with this stuff but I'm exhausted and about to go in for 8 hours more...
dtw 10-04-2013 07:11 PM
Cool! Glad it is working for you now.
Z-man 10-04-2013 07:13 PM
If you sum all the 3's together, you can then divide that sum by 3 to get your count of the number of 3's, and go from there.
Whoops - I guess I'm a little late to the Excel party... :D
-Z
lendaddy 10-04-2013 07:15 PM
I've gone that route before but in this case it would add yet another calculation to this "single cell" string. I'm trying to keep it as clean as possible. I do appreciate the idea though.
