Go Back   Pelican Parts Technical BBS > 5 - Miscellaneous > Off Topic Discussions
GWN7's Avatar
Tare weight of the tank is stamped into the tank. On the valve shield. Tanks are manufactured and then weighed, then stamped with the weight.
Bunch of old cars
Old 10-17-2013, 01:59 PM
Joe Bob's Avatar
I'll look when it's light and my eyes aren't crossed.....
See me for graphics. www.nbdgraphics.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 10-17-2013, 08:22 PM
GWN7's Avatar
It will look like this:
Bunch of old cars
Old 10-17-2013, 08:53 PM
Joe Bob's Avatar
Makes sense. Amazing how clueless the local W&M enforcement people are.
Thanks for the information, Bruce.
Old 10-17-2013, 09:09 PM
T77911S's Avatar
Originally Posted by Vipergrün View Post
Got tired of running to Home Depot or the local gas station to exchange propane tanks for my BBQ.
Decided to actually get my 3 tanks filled. First tank filled, picked it up to put it in the car and immediately noticed how heavy it was. The guy filling the tank indicated that it's commonly known that the 'off the shelf' tanks are not filled to capacity, but typically in the 3.5-4 gallon range, but you are paying for a 5 gallon tank.
The propane gauge on my grill agrees. The new tank had a much higher initial reading and has stayed higher after many cookouts. Ok, so perhaps not scientific.
Anyone else notice this?
BTW, I keep two full (now they are) spares on hand at all times in case things go South and I need to cook or boil water.....
-b
YES!
i went to home depot and was looking into doing an exchange since were i normally get it refilled is further away. but, the price semmed too good. i was reading the board and it did not come out and say it but it sounded like i was not getting my 20lbs of propane. so i went back to getting them refilled.
i was thinking they were more like 15lbs, but i could be wrong.
i wonder how many people dont realize they are not getting 20lbs?
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 10-18-2013, 02:51 AM
It'll be legen-waitforit
stealthn's Avatar
It is illegal here to fill them over a certain percentage....
Bob James
'79 911SC Targa - Sold
06 Cayman S
Old 10-18-2013, 05:55 AM
GWN7's Avatar
That would be 85%. At 85% the volume of the tank is 20 lbs of propane (for a 20 lbser). All tanks are only filled to 85%, no matter what the size. If they are overfilled (and it happens) the relief valve at the back of the fill valve will open and vent the contents (spring loaded) until the internal pressure is reduced then the valve is suppose to shut. Sometimes they don't and the whole contents is dumped. On larger tanks (250 gal, 500 gal, 1000 gal ect) they have a separate relief valve.
The procedure for filling a 20 lbs tank is:
Inspect the tank for damage. If there is a dent in the tank or the shield or base ring is damaged. They are not supposed to be filled.
Place tank on scale and read the Tare Weight on the tank.
Add the Tare Weight and the contents weight (IE 10, 20, 33 or 100 lbs Most common tank sizes) Then add 2 or 3 lbs (depends on what size the nozzle is the supplier uses to fill the tank. Some weigh 2 lbs others weigh 3 lbs.
IE Tare weight 18 lbs + 20 lbs + 3 lbs nozzle = 41 lbs
Set scale to 41 lbs
Attach fill nozzle. Open tank valve. Then start pump from supply tank and open fill valve.
When scale hits the set weight shut off supply valve. Close tank valve. Remove supply nozzle. Return tank to customer.
This way if the tank is not empty when brought in for a fill it will never be overfilled.
Just to confuse things new tanks up here ...the Tare Weight is now in kg's
Bunch of old cars
Old 10-18-2013, 07:32 AM
Actual Porsche owner
wdfifteen's Avatar
Will refillers fill any tank, or do the exchange outfits (Blue Rhino etc) have some kind of exclusive use of their tanks?
Old 10-18-2013, 07:55 AM
Joe Bob's Avatar
Rumor has it.....the new Rhino tanks have a magnetic interlock that only works at their site for refills. The two tanks I have been indy refilled, so......
Personally the pounds, gallons, tare, KG is a deliberate conspiracy to make the propane products beer drinking wankers in Fluriduh rich.....just sayin'....
Old 10-18-2013, 08:15 AM
The valve on the Blue Rhino tanks are not a rumor, they are being changed out as tanks are being exchanged. They are being advertised (by Blue Rhino) as a safety feature to prevent "unauthorized refilling" and over filling. Translation: Blue Rhino refills tanks the correct way and they want control over who refills them. Of course, any certified re-filler knows and employs the correct method as well.
As Joe Bob mentioned, the valve uses a steel bearing to block re-fill without using a special adapter which applies a magnet to the side of the valve. Some re-fillers have figured out how to move the bearing out of the way, and soon, I'm sure, a third party will make an adapter that will work. In the meantime, indie re-fillers will probably not mess with them and customers will have to return to Blue Rhino to get their 15 lbs. of propane at 20 lb. prices.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-18-2013, 09:13 AM
Joe Bob's Avatar
Y'all should be talking to yer local reps. Unless ya wants the King of the Hill running yer BBQ bidness.
Personally, I love charcoal cooking for big festivals but for me and the occasional Betty, the Propane closed hood cooking is the schizzle.
Old 10-18-2013, 10:47 AM
Aragorn's Avatar
Maybe charcoal is safer also:
Y! SPORTS
bunch of random cars and bikes.
Old 10-18-2013, 12:41 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
