-   -   Need some small block chevy research help (http://forums.pelicanparts.com/off-topic-discussions/778033-need-some-small-block-chevy-research-help.html)
Schumi 10-23-2013 09:56 PM
Hi gents. I've got an unusual, for me, question;
I got ahold of a small block chevy for a.. little project I'm working on. Running motor, good condition; bought it cheap off a guy and didn't really care what it was. I thought it was a 350. It's not. It's a 327. And after getting it home and cleaning it up, the numbers say it's a 327 from something along the lines of a 1967 Corvette. I think. It's all numbers matching and original. It's got the 'double-camel hump' heads with 462 casting numbers. The block and heads have casting numbers that identify them as late 1966 pours- 1 head and block on the same day, 1 head 1 day later.
Seems to have it's original exhaust manifold, which are the 'ram horn' with the 2.5" outlets, which I've seen on Vettes but not sure what else.
Engine block casting # is 3892657
The stamping code starts with a V and has the suffix of "HF" No vin, too early for that.
Here's my big question- I can't find what the suffix 'HF' would have meant in 1967. What car is this motor originally from? I'm thinking it came from a Vette.. but would there have been a Camaro that these numbers would have worked with in 1967? The HF suffix code is what throws me off. From the pages I've found, Vettes used HF in 1965 but not 1967.
Just curious about this thing's pedigree and I am far from an expert on sbc's.
But looks like I've gotten bit with the bug...
GWN7 10-23-2013 11:06 PM
The total number of L79-powered Chevelles, Chevy IIs and Corvettes from 1965-1968 was 49,034.
Read more: 1965-'68 Chevy L79 Engine - High-Performance 327 Engine - Super Chevy Magazine
yellowperil 10-24-2013 03:36 AM
Perhaps this little book could help? WHERE are the numbers you're quoting?
Usually the number below the alternator where head meets block is the best. Do you know for sure it's a 327? Does it have a 4" bore. As you probably know the only engs with a 4" in bore are 302, 327, and a 350. So assuming the
V3892657HF is the that number than it could be as follows (if you can read the printed page it all HF's from 3rd line to line 10 inclusive) if you can't read them I can quote them for you. Let me know.
http://forums.pelicanparts.com/uploa...1382610905.jpg
http://forums.pelicanparts.com/uploa...1382610962.jpg
RANDY P 10-24-2013 08:03 AM
It's a 4" bore block.
the only difference between that and a 350 is the Crankshaft n pistons.
Good to go. Swap the crank + new pistons.
PS if you're tempted to hot rod those heads- DON'T. There's no accessory bolt holes on the front so mounting alternators and stuff will be a PITA. Don't waste your money on that.
Buy some factory Vortec heads.
Dantilla 10-24-2013 08:36 AM
I recently learned that Corvette "Ram's Horn" exhaust manifolds are highly prized.
Designed by Zora Arkus-Duntov, they flow better than any other factory manifold.
I've got a '68 Chevy pick-up, and the old Chevy truck gang drools over finding Corvette Ram's Horns.
Trucks also came with Ram's Horns, with the outlet pointing stright down. The Corvette version angles back, and has larger openings- Better flow, easier to get everything to fit within the frame rails.
RANDY P 10-24-2013 08:46 AM
PS before I make you jump off a cliff there is ONE more thing to check-measure the main journals of the crank.
Likely you have a "Small journal" block, any 350 crank is NOT a drop in fit. Your options include turning down a 350 crank in a shop, buy an aftermarket crank, or you can buy a 383" stroker kit- a factory 350 crank for that engine basically doesn't exist.
One other thing- that crank in it is FORGED. They all are, think about that for a minute. It might be worthwhile to keep it a 327.
rjp
speeder 10-24-2013 09:01 AM
Where did he say that he wanted to make it into a 350? He only said that he assumed that it was a 350 when he bought it and then later discovered that it was a much rarer 327.
RANDY P 10-24-2013 09:08 AM
goood point. I thought he really wanted a 350..
rjp
speeder 10-24-2013 09:25 AM
FWIW, my ultimate Corvette would be a '65 F.I. 4-speed, 327/375hp. That was the king of the hill until '66, when the BB became available, (396).
I always thought that the BB cars, while undeniably the most valuable, were less desirable because of excess weight. There are equivalent examples in the 911 world, like everyone wanting a fat pig G50 Carrera, etc. But I digress...
yellowperil 10-24-2013 09:34 AM
Right and the 327 is a very desirable engine, and for me my favorite. The 350 is fairly common but a great engine, I've got one in my '29 hotrod.
Would rather have a 327, but no matter. Also I can't speak for Schumi, but I'll bet he's OK it being a 327.http://forums.pelicanparts.com/uploa...1382632380.jpg
http://forums.pelicanparts.com/uploa...1382632418.jpg
id10t 10-24-2013 10:05 AM
Only thing I can find for a 327 code HF is in either a 1965-66 Camaro, the HF code is also used in 1968 for a 327 Camaro which this engine could have been in. The HF code was also used to describe a 350 in a Camaro in 1969 and 1978.
here is the site I found
Chevy Camaro Engine Suffix Codes
Schumi 10-24-2013 10:09 AM
I'm not going to be doing anything to the motor other than insuring it's healthy. In fact, 327ci with these heads and the intake on it (an old, hi-RPM edelbrock) will do just fine for my application...
id10t 10-24-2013 10:21 AM
A second reply to my posting on another forum indicates that HE was the code for '67 'vette - you sure it is HF and not HE ?
id10t 10-24-2013 12:18 PM
And another reply -
1966 HF 327 Powerglide, A.I.R. 275 4 full size
See - Small Block Chevrolet Codes
sammyg2 10-24-2013 12:38 PM
I really like the 327 over the 350, in a lighter weight car. Nothing better than an oversquare engine when it comes to revving up quickly.
If you put it in a heavier car it won't be able to spin up so quicky which kinda ruins the deal.
Plusm, iffn them are 2.02 heads they'll really flow well for the 327 but are more restictive on the 350 simply due to the larger displacement.
Makes it even worse if you have the 1.94 heads.
GWN7 10-24-2013 02:17 PM
65-66 Camaro would be a really rare car. :)
According to that list my 68 327 isn't a 325 hp engine, yet the build sheet I got from GM several years ago says it is. :)
My 68 327/325:
http://forums.pelicanparts.com/uploa...1382649440.jpg
Schumi 10-24-2013 03:22 PM
The stamp definitely looks like an HF.
'full size' in 1967 would have been an... Impala?
yellowperil 10-24-2013 03:31 PM
My book (see above post earlier) defines IMP as "Bel Air, Biscayne, Caprice or Impala".
In any case, I think you've got a great motor! Good luck.
herr_oberst 10-24-2013 03:51 PM
Hmm, is that gonna go into a certain big Mercedes?
Schumi 10-24-2013 03:56 PM
Nope! Her V12 is still purring like a kitten. That reminds me to make an update to that thread, the car has gone 6 months almost trouble free.
Schumi 10-24-2013 03:57 PM
It would be a badass motor for the Mercedes though... about the same weight as the V12 but I'd gain a lot of room and get rid of a lot of crazy electronics.
Hell, the R129's engine bay is so big, I could probably fit two small blocks in there back to back.
johnsjmc 10-25-2013 06:33 AM
I think you have a 327 with 1.94 camel hump heads They were called 275 in some body styles and 300 hp in others. Cast pistons hydraulic cam 10:1 comp either a carter o later yrs used a quadrajet. The high horse 35o hp and up used forged 11:1 pistons and 2.02 intake valves same chambers and ports. Pre 68 no accesory bolt holes in the front of the heads.
In 68 or 69 the crank journal size was increased and the hard one to find has a large journal steel crank and bigger bolt rods.And the heads have mounting holes but still use the high compression chambers.
Schumi 10-25-2013 07:17 AM
It's got a Quadrajet, and it seems like it could be the original carb.
It's had head work at some point in it's past- it has upgraded double valve springs, and they are larger. The seats were machined for the larger springs, and the seals are upgraded to the full circle kind, not just the umbrellas on the exhaust valve. It also has original rod guide plates.
Can't wait to hear this thing run.
johnsjmc 10-25-2013 08:31 AM
Heads with guide plates says 2.02 and machining for BBC springs was fairly common for added lift. Screw in studs and plates were post 68 OEM. on 302's but not those castings
RANDY P 10-25-2013 08:42 AM
Feel free to sell me the carb :)
I like Q Jets.
rjp
Schumi 10-25-2013 11:49 AM
It's got screw in studs... they would have to be aftermarket if they didn't do screw in until 68.
It's a hot one for sure. You guys wouldn't believe what we paid for it. We got it thinking it was some 80's van motor. It was dark when we picked it up, and we were late and didn't want to inconvenience the seller any more than we already had, so we didn't look too close at it before loading it up. Then it sat in my buddy's trailer for a while because he was out of town. Finalyl we got it in my garage and ... what do you know... it's definitely not a van motor...
LWJ 10-25-2013 04:44 PM
My father purchased a 69 3/4 ton long bed when I was in HS. It had a similar 327 transplanted in. That truck just pulled like hell! I assume the truck weighed 4500#. Put that power plant in something under 3000# and you will have an ear to ear grin.
gamin 10-26-2013 10:47 AM
My son blew the 305 (?) in his 70 Nova. We found a rebuilt 327 double hump heads 4 bbl purely by accident for $500. Put it in the Nova ahead of a 3 sp manual and will that thing fly, in a straight line of course. He got a lot of tickets in that car. Now it is all restored and looking good in marina blue. You can't go wrong with a 327.
masraum 10-26-2013 11:20 AM
My son blew the 305 (?) in his 70 nova.
If it was the stock motor, it would have been a 307.
Jim Bremner 10-26-2013 11:22 AM
4" bore 3.25 crank. It's what my Small block ford got stroked to. I had more head but it made 364 rear wheel hp so figure 420ish to 450 at the flywheel at 6,400 rpm.
It rev'ed pretty quickly.
So, what will you stick it in? What trans? If you're trying to build a hotter motor out of it? I would recommend to have a custom cam ground for it and dyno tune it you'll be amazed
Tobra 10-26-2013 06:52 PM
My brother had that 327/300 motor in a 68 Camaro, that car was so very fast. Red metalflake paint, black vinyl interior with front seats out of a 69, so it had head rests
