Wandered off somewhere...
Broken bolts/studs… Removal ?
I'm in the process of restoring an old Wedgewood gas range I've had since about 1980. Bought it from the original owner who bought it new at Sears in 1954. Anyway I was trying to remove the burners and the attachment screws are notably tight and near frozen. I soaked them in PB Blaster for a long time. All but two came out. The other two were turning but it was the head twisting off and I couldn't tell. I have researched on YT on how to remove w/o drilling them out and retapping but I'm able to do that if need be.
Bought a set of Easy Outs but not used them yet. Still soaking in PB. Vise grips just slip. Wondering if torching them to heat up would help or make it worse…if that's possible Any other ideas before I try the easy outs ?
Mark... Porsche Boxster S 2012 Jeep Wrangler Rubicon..Crush Orange |
Recreational Mechanic
Drill out with left handed drill bits. Cycle heat cold a few times with MAP gas then try ez outs again before drilling.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Tried my easy outs…no luck. Finally drilled them out and will tap new threads tomorrow...
how much of the stud is sticking out, or did it break flush with the mount? I have had great luck with this tool if you have about an inch of stud to work with....
![]() edit: saw you got it done
-mike |
Only about 1/8" sticking out. This piece that needs threading is old cast iron I think. The bolts have been in there since 1954 so it's a wonder I even got six of the eight out w/o breaking.
If you connect to it electric current always works. Connect the stick welder plus onto the bolt (or hold it tight with your hand). Put the negative on a metal part of the sink.
Pulse the welder on and off in 1 second hits.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Anti-sieze. So in 59 years this won't happen to you again.
The only place I could find a LH drill set was from Snap On......not cheep. They are now separated safely in the far reaches of my tool chest
JPIII Early Boxster Last edited by J P Stein; 10-28-2013 at 04:53 AM.. |
Now in 993 land ...
McMaster-Carr ![]() G |
Get the Cobalt.
JPIII Early Boxster |
Harbor Freight sells them as well, I have a few sets from them, and they work just fine.
Von http://vonsmog.com 73' 911T Coupe, 76' 911S Targa 73'& 80' Mercedes Unimog DoKa 59' Austin Healey 100-6 |
Try drilling out a busted off 911 exhaust stud.
