-   -   cellphone question- emergency calls only ? (http://forums.pelicanparts.com/off-topic-discussions/780411-cellphone-question-emergency-calls-only.html)
rfuerst911sc 11-07-2013 03:35 PM
I work at a defense contractor in an old building. Recently I have been getting error messages on my cellphone when trying to make a call. The message states " emergency calls only " and the only option when this message pops up is to hit " ok ". But nothing happens when you hit ok. Not sure if IT at work is making changes or not. Anyone else get messages like this ? Anything that can be done to correct ?
Rick V 11-07-2013 03:43 PM
I get those when I have no service, or when my sim card went tits up
gtc 11-07-2013 04:42 PM
Sounds like a sim card error i was having on my HTC 8X when i first bought it. I guess the sim tray wasn't holding the card in place well enough. I just made sure the sim was really clean, and jammed it in there so it made good contact. All better now.
masraum 11-07-2013 04:43 PM
Yep, that's usually an indication that you don't have a connection to your cell provider, but you may have a connection to another providers network that will let you male emergency calls or you're cell provider doesn't recognize your phone as being authorized on the network.
rfuerst911sc 11-08-2013 03:03 AM
I'm only guessing but if it was SIM card wouldn't I get that message all the time ? Outside of work I don't recall ever getting the message. Thanks for the replies.
lendaddy 11-08-2013 12:56 PM
You likely buttdialed 911. Many cell phones lock on 911 only once it's been dialed. You need to pull the battery to reset. There likely is a menu that turns it off as well, but pulling the battery works. I work in the 911 industry and we get dozens of these a week.
cashflyer 11-08-2013 01:24 PM
Maybe the defense contractor has cell jammers installed in the building?
JAR0023 11-08-2013 07:36 PM
I'll vote SIM card. I once had a POS Samsung on the POS AT&T network and I had the same error intermittently until the third new SIM card finally did the trick. Just for the record AT&T may be great in your neck of the woods but there coverage is worthless in my AO. -J
ETA - You should be able to stop by a local store and have them swap in a new SIM card FOC. They may want to test it first but no reason a new SIM should cost you anything by time.
rfuerst911sc 11-09-2013 01:55 AM
I seem to only have the issue when at work I have not been able to duplicate the error outside of work. For now I'll let it go but thanks for the tips on the SIM card.
