-   -   Tiny Darkroom Project (http://forums.pelicanparts.com/off-topic-discussions/781987-tiny-darkroom-project.html)
jyl 11-16-2013 07:47 PM
I'm building my daughter a darkroom in the basement, using the space under the basement stairs plus a little bumpout into the rest of the basement.
The space is essentially an "L". Imagine you have a piece of graph paper. Draw a rectangle, appx 36" wide x 36" high, with a 30" door at the bottom edge. This is the core of the darkroom, where the person stands or sits on a high stool. On the upper edge, add a rectangle about 36" wide x 39" high. That is the space under the stairs, we have two stacked and staggered counters for developing trays, the lower counter extends about 10" closer to the person than the upper. On the right edge, add a rectangle appx 28" wide x 36" high. That is a little bump out, and where the enlarger will go.
Yeah, it will be a cozy space. When she has lots of printing to do, she can use the nearby rental darkroom, it has a print developing machine, print dryers, light tables, long sinks, 12 enlargers, etc. I should add that she develops film at the rental darkroom too, because they have all the chemicals freshly mixed, temp controlled water, negative drying closet, and it costs like $2/roll. This home darkroom will be for small projects and getting away from the family.
Question is , anyone have ideas or suggestions for what I should add "while I'm in there"?
Things I've considered:
- Running water or a drain. The laundry sink is only about 10' away so I could install some flexible or PVC lines to bring water to a tap above the tray counters. A proper drain would be tough. I'm not sure why we need water in there: seems the trays can simply be filled and dumped at the laundry sink.
- Electricity: of course. There is an unused overhead light fixture under the stairs so tapping power is simple. I figure I need outlets for one or two safelights, the enlarger and timer, a radio or iPhone dock; and a normal switched overhead light. Isn't there usually also a red light outside the darkroom that comes on when the normal light inside is switched on?
- Ventilation: I'm probably going to use a bathroom vent fan to pull air from over the tray counters, through a duct leading to the nearest basement window. She'll open the window when using the darkroom. I don't want to make a hole in the siding for a permanent duct.
- Print drying rack: I could build some mesh racks under the tray counters, for prints to dry. It might be a dusty spot though.
- Computer: she currently monopolizes the family Mac when she is doing her digital photography. I'm considering trying to squeeze a Mac mini and monitor/keyboard somewhere in this tiny space.
- Storage: we 'll need storage for chemicals, paper, negative carriers, etc. There will a large-ish unused space under the enlarger counter. Maybe I can find a drawer unit that will fit there.
- Light sealing: I haven't given this much thought. I'm assuming that weather stripping the door will do it. The space is windowless, of course.
Any thoughts, tips, ideas, warnings?
5String43 11-16-2013 07:59 PM
Running water and a drain for sure, the bigger the sink, the better; lots of counter space for trays and a decent enlarger. Also space for chemicals and supplies, lots of sockets to plug things into. Room to mix chemicals and work. B/W or color? It makes a difference.
Paper seems to like cool, so maybe a small fridge. I should think a light socket, for a red bulb, above the door outside, with a switch inside, so she can signal when she's inside working. And the door needs to be lightproof. Obviously.
How much space? Need to know the size of the prints she anticipates. 11 x 14? 16 x 20? Bigger? Need to plan accordingly for trays and enlarger.
Hard for me to see why a darkroom needs space for a computer, since they don't care what the light around them is like, but what do I know?
winders 11-16-2013 09:33 PM
Film is dead....spend the money on some nice lenses for a quality digital camera and a good photo printer.
stomachmonkey 11-16-2013 09:50 PM
Processing of film and papers yields hazardous waste that your local waste water management facility may or may not be able to deal with.
In CA it's likely highly illegal to let it run off into the public supply.
If you are on a septic tank you may want to consider some type of Silver recovery system.
jyl 11-16-2013 11:18 PM
Fixer is the only problematic waste. Developer, stop, etc can all go down the drain.
notmytarga 11-16-2013 11:32 PM
Wow - a thread about darkrooms - and NO PICTURES!?
flatbutt 11-17-2013 05:14 AM
Dust will be an issue particularly under a staircase.
HarryD 11-17-2013 09:55 AM
Do you have the equipment to process film? I have an old enlarger, stuff to process cibachrome, trays etc.
Wanna make a deal?
For the papers, once you load the paper into the processing drum, you can do the rest in your kitchen table top.
mjohnson 11-17-2013 10:34 AM
All you really need is a slop bucket and somewhere else to do the rinsing. I spent 8 years doing the wet work in a closet that I built a bench large enough to hold five paper trays. This was on a bedroom/office that I blacked out and had enlargers on a desk.
Just had to get the rinsing gear out of the guest bathroom before company came...
Don Plumley 11-17-2013 11:07 AM
I had a darkroom in a side building when I was in high school. Accordingly, I imagine it is still full of my trays, stainless tanks, Durst color and B&W enlargers/lenses, timers, et al. They are at my Dad's home in Los Altos.
You are welcome to take all of it (please).
mikeatfhc 11-19-2013 05:27 PM
Jyl:
I am relatively close if you are in the SF Bay area. I have a complete darkroom sitting in storage, all kinds of good stuff - I have been holding on to this stuff waiting for someone who could make good use of this equipment.
If you are interested feel free to PM me, I would be glad to donate it all to a good cause.
Otherwise, I would add to the other responses by saying make sure you have good ventilation, it can get 'harsh' in a darkroom after a bit.
mike
Flat Six 11-19-2013 07:04 PM
Good for you; your daughter's a lucky girl. Good advice above. I'd add:
1) Make the enlarger table as absolutely stable as possible; even slight vibrations will blur prints. Separate from developing tables if at all possible. Think 'wet' side and 'dry' side
2) +1 on the drain and vent
3) Some kind of hard floor that's easy to mop if necessary; no carpet (dust)
4) Keep the drying racks high (dust); I've had success making wood frames & stapling window screen to them (prints face up to dry, face down for matte look)
5) If basement is un- (or semi-) finished, insulation and drywall -- no open studs, underside of stairs, etc.
All I can think of at the moment; good luck and keep us posted.
jyl 11-19-2013 07:14 PM
Basement is indeed unfinished, but warm and livable - her photo studio, wife's art studio, laundry, mini home gym, are all down there.
I was thinking that cleaning all surfaces, caulking cracks, then painting the studs and sheathing and underside of stairs, everything (which I need to do anyway, to make it black) would serve as dust control? Idea being, a painted stud would be as dust free as a drywalled stud?
Floor will be painted concrete with a rubber mat.
Enlarger table will be heavy wood construction, bolted into the studs.
Drying racks, keep them high - got it.
Hanging the door tonight.
Flat Six 11-20-2013 06:50 AM
I understand drywall is a PITA for such a small project, but even w/primer & paint open framing and backside of sheathing will gather much dust.
Just thinking out loud, but maybe staple & seam tape plastic sheeting to the framing? Fast, easy, cheap, and creates a dust-free barrier that's easy to wipe down? Might even be able to find some thick (2-3 mil) in black. Just a thought.
M.D. Holloway 11-20-2013 06:58 AM
Wow! Developing film the old fashion way :) Thats pretty cool. I love to hear it when an artist mixes their own paint, or a carpenter harvests their own wood.
jyl 11-20-2013 07:19 AM
Hmm, thinking about it, to skip drywalling would be lazy/cutting corners. I really only need to drywall the bumpout I framed for the enlarger, the underside of the stairs, and the ceiling. Okay, I will probably do the drywall.
GH85Carrera 11-20-2013 07:23 AM
There is no better way to LEARN the basics of photography. Watching a image appear on the paper as it develops is just cool. She will learn more about how to make a good photo with B&W printing and processing the film herself than all the books she can ever read.
Have her turn of the automatic exposure feature on the camera. Learn to gauge the exposure on film by bracketing the exposure. See the difference of 1/2 stop under or over exposed. It can be a ton of fun and great learning.
Once that is "burned in" to her brain move on to good digital cameras. All of that core learning will make he a better photographer.
I really hope she has a different career path. Very few professional photographers can make any money. Find something else to pay the mortgage. The would has gone to the "good enough" standard. My cell phone will shoot a picture better than my film camera from the 70s.
Rusty Heap 11-20-2013 08:17 AM
I used to bulk roll my own B/W film into 35mm film canisters, bought it at 250' a roll if I remember right.
I'm just curious though, she already has full access to a large rental darkroom with 12 enlargers and all sinks/chems/trays? An you want to put her in a closet with no room to work?
Steve Carlton 11-20-2013 08:25 AM
I'm scared of the darkrooms.
Flat Six 11-20-2013 08:53 AM
Me too; Alden 74 IIRC.
Agree w/Glen that watching an image appear in the dark before your eyes is magical. But the 'print/film vs. digital' question typically focuses on output -- quality of the final image.
Film typically has greater dynamic range than most consumer image sensors, even when exposed and/or developed less than perfectly.
But to me the bigger issue is how technology -- any technology -- fundamentally changes the creative/artistic/technical experience.
For example, most of us communicate differently -- different content, different tone, different expectations -- depending on whether we're texting, tweeting, e-mailing, using a word processor (?!?), typewriter, pen, pencil, chalk, or fountain pen. Not only is the outcome/product different, so is the process and the nature of human engagement in communication.
Same thing happens w/photography. The fundamental nature of human creative experience (not to mention the vast difference in technical understanding of how images are made and what makes for a compelling image vs. not) is very different with a phone camera, SLR, digital SLR, view camera, point-n-shoot, film negative, film positive, 35mm, Minox, medium- or large format, or instant. You want photographic magic and wonderment? Get a Polaroid pack camera and some Fuji B&W instant film -- you'll see the world very differently.
Same reason many here prefer analog to digital or air-cooled vs. liquid-cooled. To me, Porsche is an experience; Miata is an appliance.
Sorry to get OT and sideways on you, JYL. I applaud and appreciate that you're supporting your daughter's interests in this way; her interest in film photography can have some far-reaching effects.
