Engine Oil Extractor
I am not planning to use an oil extractor on anything that I can drain it out of, but our new boat with a Mercruiser 4.3MFI requires an oil extractor to get the oil out of the engine.The one I am leaning to is the Moeller 5.0 Liter Fluid Extractor Oil Change Pump.
Moeller Marine Fluid Extractor/Oil Change Pumps Anyone have any advice. Thanks |
I have the Motive extractor that I use for my 4.3 Mercruiser. It works well but is SLOW, as in over an hour to extract under 5 qts of warm oil. I don't know if mine isn't working correctly or is simply flow limited by the little tube that shoves down the dipstick hole.
I ordered and have this one...$93 + Free Shipping.
Haven't used it yet because I still have free oil changes on the Abarth. . Amazon.com: Mityvac 7300 PneumatiVac Air-Operated Fluid Evacuator: Automotive |
have same as Don, works fine!!
For hand pumped extractors, ensuring there are no vacuum leaks and extracting oil at operating temp makes things much more time efficient. Small vacuum leaks are difficult to notice.
Mine holds the vacuum very well and is new this year, so I don't think it is a wear thing. I just start the engine oil extraction then go change the oil in the out drive, change the fuel filter, etc.
I bought the west marine one and it will suck out warm oil quite quick. The size of suction hose will have a lot to do with evacuation rate.
We bought the harbor freight one.... It's still in the box so idk how well it works. Didn't get to use the jetski much this season...
The one I bought operates on compressed air to create a powerful venturi vacuum for draining fluids from tanks and reservoirs. Compressed air hose attaches at base for stability. No hand-pumping.
| All times are GMT -8. The time now is 08:36 AM. |
