Guess what this is WITHOUT using the Internet
It's a tension bar. I did not peruse the internet, never had to leave PP to figure it out. Can you guess how?
Shear pin?
right click on pic, click on properties, read title. |
Very easy, its a tension bar from the USS Bennington. Doh
Dilithium crystal from the USS Enterprise
Main shaft shear pin from the USS Bennington?
You made the task impossible.
I have to use the internet to even see the question and access Pelican. |
it is something that should be worshiped ... its an idol of the God 'Pin' and sacrifices should be made in PINS honor...
Looked like an overhead roller pin for a sliding crane often found in industrial shops to me.
I think the bigger question here is why was it in your wife's nightstand?
Tension pin from a carrier catapult
I suggested it looks like a shear pin which is typically designed to limit torque to prevent overload damage. The necked down portion is supposed to shear off at a specified load to prevent other components from breaking. An intentionally built in weak link that's easy to replace. Still awaiting verification to see if that is what it is ............ |
Looks like the pre-shake weight! ;-)
Baby Rattle
I have something that looks similar to that. guess what this is.
http://forums.pelicanparts.com/uploa...1387476493.jpg |
http://www.southbayriders.com/forums...hments/362564/ |
Grenade?
| All times are GMT -8. The time now is 08:54 PM. |
