least common denominator
Audio experts, static from power amp at startup
Tested the source and the speakers are new so I am down to the power amp.
Symptom: At power on a slight crackling or static (like cellophane being crunched into a ball) comes through the speakers. Exact same static comes through at start up with the source set to Aux., CD, (static is constant when switching source) speakers are relatively new (under a year). What think ye? Thanks in advance, Scott P.S. Obviously (from the title) I suspect the power amp, and therefore a bad capacitor... power supply or signal path? P.S.S. It only happens for ten or twenty seconds until the system warms up so it is not the end of the world but it bugs the heck out of my OCD self.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Nobody?
Used Up User
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
Student of the obvious
More info would be helpful... What kind of amp? Integrated? Power amp + preamp? Receiver? Brand and model?
Lee |
It only last for 10-20 seconds at startup,but stays consistent when I switch between souses (Aux, bluetooth, USB, tuner, CD) until it goes away.
I would call Soundstream and let them know.
You do not have permissi
Is there a (+12v) inline filter to throw at it?
Is the amp ground separate from the engine ground? Both clean and tight? Sorry, I know nothing in this. Last edited by john70t; 03-13-2014 at 08:41 AM.. |
Sounds like power amp capacitor...
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Can you hook the speakers up directly to the head unit to take the amp out of the mix?
I'd then try something like running a cable directly to the amp's input (ie... a 3.5mm to rca cable plugged into your phone or ipod. Doing the above should allow you to isolate which component is causing the issue. Does it do this every time? So, if you have the car running and turn the power off on the unit, then turn it back on do you get the same results? Or, does it only happen when you've started the car. What I'm thinking is, if it's the latter, then maybe something in the car's electrical system is energized temporarily at start up. I second the question about the 12v in line noise filter. I bought an external Sirius satellite box that had lifetime service. Hard wired it in my car and had a nasty buzz. Put something like this in the mix and now it's silent:
Lee |
Did you try unplugging the RCA connections from the amp and then turning it on? If it makes the same noise without any input it narrows down the amp (bad caps or solder joint), is the AMP and the head unit grounded at the same place and same connection for power? if not it can cause ground loop.
87 930, |
Could also be a bad contacts on the relay inside the amp.
87 930, |
No Band
He was a helluva plumber and his outfit was self explanatory |
![]() OK, so I will try unplugging the RCA to the amp and see if I still have the static... and run a test with my cell phone again. Amp is in the trunk and head unit is in the dash, I presume they both ground to the chassis. I am only running the RCA pre-out of the head unit, I would have to pull the dash to get to the speaker out of the Alpine, all unused wires are taped off at the ends to prevent shorting. I also suspect a component running at at startup... but this is a 1995 Miata with crank windows and not a lot of electrical accessories and the static is not consistent... it goes in and out then after a few seconds goes away all together. I will try soundstream but the amp sat in the garage for a couple weeks before I got it installed... then I got the new head unit and installed it... so it has been a couple months since I bought it.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. Last edited by scottmandue; 03-13-2014 at 08:31 AM.. |
You never said whether or not the noise is only there for a few seconds when the car starts vs the stereo starting.
If you've been driving and turn off the power to the head unit, then turn it back on do you get the noise again? If you start the car with the radio off, drive for a while, then turn on the stereo do you get the noise? If you turn the car on, hear the noise, let it run its course, then turn the car off and immediately restart do you hear the noise again? Same results on warm and cold starts? Do you have an external 12v power supply that you can use to energize the stereo equipment. Maybe pull the battery from your other car so the stereo equipment is isolated from the car's electrical system? The ebay noise filters are cheap and easy to install. Took the noise from my radio - but it was a different noise - I had the whine/hum that's tied to engine speed... sounds like an audio tachometer.
Lee Last edited by LeeH; 03-13-2014 at 02:30 PM.. |
