Yeah, but the old box already has 6GB of it and right now I don't have the $100.
No new motherboard uses DDR2, it has served you well, junk it or sell it on eBay, somebody may buy it...
I hear you. Thanks.
That Gigabyte MOBO has dual channel memory slots.
You can populate and run with one 4 GB stick and add a second as funds / needs dictate. Current Microcenter circular has a PNY (name brand) 4 GB stick of DDR3 on sale for $37.00, a no brand 4 GB stick for $34.99 and a Kingston 8 GB 2 stick kit for $79.99 Or Tigerdirect, 1 4GB stick DDR3 $35 out the door plus $5.00 rebate get's it to $29.99. Disclaimer: tigerdirect were a partner when I was at CA and their rebate center sucked, you need to do everything right. ADATA XPG V1.0 Destktop Memory - DDR3 1600, 4GB, Blue - AX3U1600W4G11-RD at TigerDirect.com |
I use Acronis True Image Premium to image copy hard drives...
You could always do that Quad core CPU bundle at $69.99.
Performance wise it's a small notch up from what you have. Not demonstrably better but still better. |
Been reading up on RAM etc to see what options I have.
It's looking like it may be more cost effective for me to just go get a whole new box. The broken one is 6 years old and so are all the peripherals in it (fans, pwr supply etc.). If I got a new box with SATA drive(s) in it, could I just sub my present SATA drive in or would it be easier/better to use it as a slave? I was running Vista 64 without any problems, and liked it better than my wife's Win 7. I don't really want to go to WIN 7 or 8, but if that's what will be so be it. If looking at new boxes, what cpu should I be looking at as a minimum? The old computer handled my pics and videos fairly easily and quickly. I'm not sure how much of that was due to its being a quad core processor. Any suggestions would be helpful. If I have to I'll use my DVD player/burner from the old computer. I definitely will be using the old HD in some fashion as all my pics etc are on it and my old old computer won't interface with SATA as far as I know. I really appreciate everyone's input so far. Thanks. |
As far as the 6 year old peripherals. The case is not a wear item, no need to ever replace. Case fan, you can find them all day long everyday from $5.00 and up and take 5 minutes to swap out. case fan : Micro Center Power supply. You can get 500W starting at $20.00. 15 minute swap. Diablotek EL Series PSEL500 500 Watt ATX Power Supply PSEL500 - Micro Center CD/ DVD. For readers only $10.00 and up. Writers $15.00 and up. 5 minute swap. dvd drive : Micro Center Hard Drive. 1 TB 7200 RPM SATA drive, $55.00 and up. 5 minute swap. Toshiba 1TB 7,200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive DT01ACA100 - Bare Drive 965038 - Micro Center Add in the the $69.99 AMD bundle plus new RAM you can walk out of Microcenter with everything you need all at once for $200.00 Personally if funds are an issue I would not replace functioning peripherals until necessary. I would strongly consider grabbing a hard drive as that is the most critical component related to data loss but the other stuff I'd take a wait and see approach. If you are totally paranoid about data loss grab 2 hard drives. The Gigabyte board in the bundle has an onboard raid controller. |
OK. So the gigabyte bundle + the Kingston 8gb 2 stick ram package, a little work to r&r the MOBO and I'm up again with close to or a little better performance than the old computer had, and it's only @$160.
Is the video 'built-in'? |
AMD Phenom II X4 955 vs FX 4130 You may see some small gain from the MOBO as well. MOBO has onboard VGA and DVI. |
| All times are GMT -8. The time now is 03:25 AM. |
