Question Replacing VW Head Gasket
Hello Everyone, SmileWavy
I have a question regarding using sealant on a head gasket. I'm working on a 2002 VW Golf with a 2.0L engine. I'm replacing the head gasket because I had water leaking into the exhaust which has clogged the 02 sensors, (both) and is clogging up the CAT. :mad: The Fel-Pro gasket I bought is a MLS gasket (Multi Layer Steel) and according to Fel-Pro no sealant is necessary. I was considering using a sealant only because this is a big job and I'm spending a few hundred dollars on O2 sensor and a CAT and I don't want to have to do this again. :( Do any of you have experience using sealant on MLS gaskets? Thanks in advance. :) L |
When I did the top end/cooling refresh on my Series I used a MLS gasket.....no sealant and no problems.
did you get the head cut/valve job? a straight head is more important than a gasket sealer.
i used that copper spray gakset on the head of my mazda. it really depends on the gasket materiel but i dont remember what mine was. |
Hi, unless I am missing something in your post you state you had 'water' (coolant?) leaking into the exhaust. The only way for this to happen is there is a breach in the cylinder head between cooling passages and exhaust seat / port.
If your head gasket has failed you'll have coolant in the combustion chamber, which then exits into the exhaust. If this happened that combustion chamber will be clean as a whistle and you'd have misfire codes......................... If you're not sure, you'll need to have the cylinder head pressure checked to rule that out. |
What asphalt said. I send every head out, and have it pressure checked, and milled . It prevents comebacks.
Gasket goes on dry to a perfectly milled head and a really clean block surface. If you are trying to get by without milling the head, a few light passes of that spray gasket may not hurt. I don't see those cars blow head gaskets all that often. I am usually removing the head because a belt broke, and smashed all the intake valves Good luck |
It is coated with a polymer or is it a straight up steel surface?
I would go on a VW board and inquire. Generally FelPro is a top company, and I would go with their recommendation. I have used MLS gaskets from them before and they were all coated with some sort of polymer. G |
Check to make sure the head bolts are not TTY.
| All times are GMT -8. The time now is 09:58 PM. |
