2004 Chevy Tahoe HVAC question...
Not much information to go on as I just picked up the car tonight from my brother, but I know the power of PPOT.
It's a 2004 Chevy Tahoe 2WD with a 5.3 and 104K on the clock. It has dual temp controls and rear HVAC. With the emgine and AC on, it blows hot air out the drivers two vents and cold air out the passenger side vents. The rear blows cold. Are there any common problems that would cause this? Could it be a bad dash temperature control unit? A bad flapper in the dash? Any other information needed to go on? With a new battery, tires and a detail, it's going to be a great 4th car for us. |
The Unsettler
Most likely a flapper.
They can get out of sync if you start them up with the HVAC running. Best practice is start car with HVAC Off, wait a second or two then turn on. That said the motors also burn out. You can hear the flappers move, get everything going and switch between floor and dash vents. Listen for flapper moving. If it's the center dash vent you can pull the panel above the tranny tunnel and see it actuate. 104k on the clock is nothing for that motor. FWIW, don't let the family slam the doors, my most common maintenance item on both my Tahoe and Yukon are window actuators. The plastic take up reels break. Cheap and easy to replace though, just annoying.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
You have a bad drivers side temp door actuator. Very common problem. There is one for each side. One is located on the bottom of the hvac box near the center bottom of dash. The other is on top of the box near the center of dash just visible thru glove box opening with glovebox removed. You will have to check and see which one moves when pass side temp is adjusted and the other will be your culprit. Only buy the new actuator from a dealer with the last 8 digits of your vin. Nearly impossible to get the correct one from an auto parts store. Do not plug in new part until it is installed either. If it is the one on top of the hvac box it calls for something like 7 hours to replace by way of removing dash. I have done dozens of them in less than 30 minutes thru glove box opening. Not easy but doable.
Funny...I've been chasing a rear that a/c won't work on my 2002 Yukon. Additional problem is that no one here in Stuttgart is used to working on GMCs so they are clueless. Fortunately, the front a/c does the job here as it doesn't get too hot. They share the same freon lines, so I'm convinced there is something electrical not turning on the rear evaporator. Uggggh!
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
The rear one doesn't work...no pool of water dripping from the back like it always did. Warm air out of the vents.
After doing some reading online, it might be an actuator. I'm reading the driver side HVAC actuator is either on the passenger side above the transmission tunnel or the gas pedal. Maybe the year determines this?
Just thinking out loud
Happens all the time when a battery dies or is replaced on those vehicles. You need to pull the hvac fuse, 10amp, under the hood, with the ignition turned on. Then turn off the ignition, replace the fuse, turn ignition on, do not start, let sit for two minutes, you should hear the actuators cycling, turn ignition off, then on. Should return to normal operation. Repeat as necessary. Also changing the temperature setting on both sides to full hot, or full cold during the process can help too.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 06-12-2016 at 07:10 AM.. |
Thanks guys. I'll give your ideas a try!
pen 15 nailed it....Door actuators are very common on the Chevrolets. Drivers side actuators are easy to replace. Just remove the passenger side lower insulator panel under passenger side glove box area..usually 3x7mm screws..The actuator is on the bottom of the heater box.. 3x 5.5mm screws hold it on.located just to the right of the centre of the heater box. I replace these on the daily at the dealership I work at.
Chris
Chris 89 930 slantnose M505 k27, BB headers,kokeln I/C Last edited by boosted 89; 06-12-2016 at 04:48 PM.. |
Chris
What would the dealer charge to swap it? |
