Double Trouble
targa911S's Avatar
On the bench...Henry's big one...
So Henry sent me this bench gun to fit and finish. This thing is HUGE! The action alone weighs in at a whopping 8 pounds! Barrel is 1.15" in diameter. As close as we can figure it's a .270 weatherby short magnum. It's a monster. Should be on the deck of a ship somewhere. Anyway here we go. First I had to fit the action to the semi inlet stock from Richard's " mightnot fit". I have done a couple of their stocks before and they have had problems like the action holes off center and the likes.
Here is the action the pics don't do it justice. I just got it back from the bluing tank as the barrel was almost white. The action is an Interarms mark X with this floor jack handle sized barrel fitted to it.
Inletting the wood for the action. A few hours with the a rasp and a dremel tool...surprisingly the inletting from Richard's was pretty accurate but tight so I had to open everything up a bit.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 03-13-2014, 02:20 PM
Double Trouble
targa911S's Avatar
once the inletting was done it was a tight fit but that is a good thing....lookin good here..
Now to take it apart again and start sanding..
75 914 1.8
2010 Cayenne base
Old 03-13-2014, 02:27 PM
Double Trouble
targa911S's Avatar
Once the machine sanding is done the detail hand sanding begins and then about 3 coats of nitro sanding sealer......that is for this weekend. More then...
75 914 1.8
2010 Cayenne base
Old 03-13-2014, 02:31 PM
Try not, Do or Do not
Henry Schmidt's Avatar
And so it begins......... I'm looking forward to watch this come together.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-13-2014, 03:02 PM
Hell Belcho
Nostril Cheese's Avatar
What kind of wood is that? Beautiful work.
Old 03-13-2014, 03:23 PM
1/16" Laminated Birch
Henry Schmidt
Ph: 760-728-3062
Old 03-13-2014, 03:32 PM
John Rogers's Avatar
Is it going to have a few coats of clear lacquer by any chance????? We get a few "bench rest open class" shooters and their guns now and then and they usually come to the range early in the week when it is not crowded and they will not get bombarded with questions! I am amazed at the $$$$$ that is spent on the forged aluminum rest, scope, spotting scope, etc and most are like me having a van or similar where everything fits in just right!
Old 03-13-2014, 05:23 PM
Double Trouble
targa911S's Avatar
yessir this is getting a few coats of nitro then hand rubbed tru oil over that. Henry just emailed me that he wants me to dump all the sharp edges and corners. I agree it does kinda look like an aircraft carrier. Gotta soften it up a bit. Now where is my rasp? Do not be fooled by the grey appearance...trust me it ain't grey..you will see......
75 914 1.8
2010 Cayenne base
Old 03-13-2014, 07:05 PM
Model Citizen
herr_oberst's Avatar
I love the "On The Bench" installments!
Old 03-13-2014, 07:12 PM
Double Trouble
targa911S's Avatar
Continuity baby...;-)
75 914 1.8
2010 Cayenne base
Old 03-13-2014, 07:15 PM
19 years and 17k posts...
azasadny's Avatar
Beautiful work there, David!
Art Zasadny
Learning the bass guitar
www.ford.com
crustychief's Avatar
Looks great Amigo!
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 03-13-2014, 07:20 PM
Double Trouble
targa911S's Avatar
thanks guys it's been a while since I have done one of these threads. It has a ways to go yet.
75 914 1.8
2010 Cayenne base
Old 03-13-2014, 07:48 PM
Detached Member
Hugh R's Avatar
Wow, and Wow.
Hugh
Old 03-13-2014, 08:45 PM
You do not have permissi
john70t's Avatar
Nice work.
Looking at the pics, I was trying to figure out how the barrel, any barrel, transfers its force to the stock, and had a quick question.
Please forgive my ignorance as I'm probably missing something here.
On top, it looks like the barrel has a short sleeve (at the firing chamber) held in a small divet, but there are also two large fillets at the rear of the action (next to the safety switch) which takes most of the total brunt force. The barrel is sandwiched to the trigger guard, by pins screwed together, which might also transfer a bit.
On the trigger guard assembly, it looks like it has a large flat section:
This doesn't seem to correspond with the stock:
Please forgive my nativity.
I was curious about the dynamics, and am probably missing something in the pictures.
That area might be completely unrelated to my question.
It's a fascinating process and thanks for sharing.
Old 03-13-2014, 08:54 PM
MBAtarga's Avatar
User reported to moderaters for SPAM posts
Mark
'83 SC Targa - since 5/5/2001
Old 03-14-2014, 07:08 AM
Seahawk's Avatar
Me, too. Thanks for letting us share in this a bit. You as well, Henry.
1996 FJ80.
Old 03-14-2014, 07:21 AM
The barrel is located by the mounting lugs fore and aft on the receiver.
I believe that there is a wide plate removed from the forward mount that provides most of the positioning.
The magazine housing plays no role in locating the barrel.
Henry Schmidt
Ph: 760-728-3062
Old 03-14-2014, 08:14 AM
AS I've mentioned previously: none of the weapons seen in these threads actually exist. They are computer generated images for entertainment only...........
Henry Schmidt
Ph: 760-728-3062
Old 03-14-2014, 08:18 AM
john70t's Avatar
Nice graphics from a true artist.
Sorry for the thread tangent. I'll delete my posts if requested.
Old 03-14-2014, 08:54 AM
