-   -   Ducati SS custom fairing. Opinions? How to cut it? (http://forums.pelicanparts.com/off-topic-discussions/801357-ducati-ss-custom-fairing-opinions-how-cut.html)
HardDrive 03-15-2014 06:48 PM
I have 93 SS with full side panels. They are safely packed away. I want make some very compact fairings, much smaller than the CR half fairings. The only tricky point being that I don't want to cut the subframe that holds the cowling/instruments in place. So that means the first support bolt (the one just under the turn signal) has to stay. I picked up a CR panel and taped it off in the shape I was thinking of. The tape and everything to the left would be trimmed away.
What do you think? I know it will look late 80s/early 90s funky, but thats ok. I'm going for that.
Any suggestions on cutting the fairing? I was planning on a fine tooth blade in a sabre saw. I could also go after it with with a multi-tool.
http://forums.pelicanparts.com/uploa...1394933802.jpg
Jeff Higgins 03-15-2014 09:41 PM
Don't use anything with teeth on it. Use an abrasive cutoff disc in a Dremel tool or a die grinder.
Oh, and I think it will look great. Kinda almost naked, in a Borat sling kinda way...
flatbutt 03-16-2014 06:13 AM
+1 on the disc idea.
HardDrive 03-16-2014 08:20 AM
Ouch! Lol.
