Make Bruins Great Again
Por_sha911's Avatar
Need Help with DVD RW Drive
It recognizes purchased CD's but will not recognized burned CD's or blank CD's. It just starts clicking over and over for a minute or two and then gives an error message.
Since it does read purchased CD's and blank DVD-Rs I don't think its a software issue. Tried the following:
-rebooting
-blowing out dust,
-reaching a long cue-tip in there to clan what I guess is the lens,
-pushing the lens to the back
-Windows Explorer doesn't recognize a disc in there.
I've got a 5.5 year old Dell running Vista 64 bit that works great otherwise. Full tower full height drive.
Is the drive toast? If so will any DVD-RW fit the tower?
Joe
Old 03-15-2014, 02:27 PM
Run smooth, run fast
Heel n Toe's Avatar
After burning CD's and DVD's, there's usually a step called "finalizing" that closes it out and makes it recognizable on other machines... make sure you've done that.
- John
Old 03-15-2014, 02:35 PM
Por_sha911's Avatar
Can't get the drive to see the blank CDR to burn anything onto it. Just clicking (the head bumping against the stop?)
Joe
Old 03-15-2014, 02:41 PM
Heel n Toe's Avatar
Ahhh. I dunno... that's all I got.
Somebody much more knowledgeable will be along to help you out eventually... you can be certain of that.
In the meantime, spray WD-40 liberally inside the drive door.
- John
Old 03-15-2014, 02:59 PM
The Unsettler
stomachmonkey's Avatar
The burned cd's that it will not read, where they burned by that device?
The blank cd's that it will not read, have you successfully used media from that batch before or is this new media?
FYI, the drive has two lasers, one for CD's, one for DVD's. It's not uncommon for one to fail while the other continues to function so the fact that blank DVD's work is of little relevance for the CD problem.
And stop sticking stuff in there, that's a bad idea. It's not a cassette player.
"I want my two dollars"
"Brandon Won"
Old 03-15-2014, 03:04 PM
Por_sha911's Avatar
yes
yes
I figured I had nothing to lose
So how do I know if my drive is a SATA or IDE? Dell was worthless for help. The phone rep said he had a replacement drive that is 1/2 height and I knew that wasn't correct.
Joe
Old 03-15-2014, 03:32 PM
The Unsettler
Probably easiest to just grab a new one.
They've become cheap enough to be disposable.
"Brandon Won"
Old 03-15-2014, 03:39 PM
19 years and 17k posts...
azasadny's Avatar
A new SATA DVD/CD burner is less than $20...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 03-15-2014, 05:28 PM
Por_sha911's Avatar
LG, Samsung, ASUS, Liteon
Any suggestions which one?
Joe
Old 03-15-2014, 07:05 PM
Por_sha911's Avatar
OK. I don't want to shut the system down tonight so can I tell from the info below if I have IDE DVD/CD?
The pics stomachmonkey posted was for harddrives. Would the pin configuration be the same for optical drives?
Joe
Old 03-15-2014, 08:04 PM
Heel n Toe's Avatar
Originally Posted by Por_sha911 View Post
...can I tell from the info below if I have IDE DVD/CD?
Based on: PNP Device ID ------- IDE\CDROM::::::::::
...that would be my guess.
Don't know about pin configuration.
- John
Old 03-15-2014, 08:07 PM
The Unsettler
A CD/DVD is a drive, only diff is the media and the read/write heads, otherwise same same. Spinning platters of data.
It no matter.
"Brandon Won"
Old 03-15-2014, 09:36 PM
Por_sha911's Avatar
Thanks for the help! Its a good thing I didn't go by the System Config Info:
Looks like full height to me:
Do all drives have the open/closed button configured in the same spot? The Dell has a face cover:
Joe
Old 03-16-2014, 02:25 PM
azasadny's Avatar
Just buy the 1st one you find at Newegg, TigerDirect or MicroCenter. They're all the same... I just bought one for $17...
Art Zasadny
www.ford.com
Old 03-16-2014, 02:40 PM
Por_sha911's Avatar
Just installed a new ASUS DVDCD burner from Newegg. Less than $30 with tax and shipping. Had to remove the power supply and processer fan to do the swap but easy enough.
Thanks to all who helped with info.
Joe
Old 03-19-2014, 01:50 PM
