Slackerous Maximus
HardDrive's Avatar
Linux (or Apple) guys, trying to SSH, won't work
I'm trying to SSH into a Linux box on Amazon Web Services. The public key is in my .ssh directory. I've adjusted the permission as directed by AWS.
When I try and connect, it says the file isn't accessible. Same result if I run the command when I'm in the .ssh directory. It doesn't seem to matter if I include a file path to the key either. Any thoughts on what I could be doing wrong?
jh:~ pelicanboy$ cd .ssh
jh:.ssh pelicanboy$ chmod 400 LuckyServers.pem
jh:.ssh pelicanboy$ ls -l
total 16
-r--------@ 1 pelicanboy staff 1692 Apr 23 11:44 LuckyServers.pem
-rw-r--r-- 1 pelicanboy staff 788 Apr 27 13:25 known_hosts
jh:~ pelicanboy$ ssh -i LuckySevers.pem ec2-user@54.149.XX.XX -v
Warning: Identity file LuckySevers.pem not accessible: No such file or directory.
Permission denied (publickey).
2014 Cayman S, PDK
Old 04-27-2015, 02:45 PM
The Unsettler
stomachmonkey's Avatar
Is your IP address authorized for inbound traffic?
You need access to the EC2 console to enable it.
"I want my two dollars"
"Brandon Won"
Old 04-27-2015, 02:52 PM
Slackerous Maximus
HardDrive's Avatar
Yup. Port 22 wide open.
2014 Cayman S, PDK
Old 04-27-2015, 02:59 PM
Slackerous Maximus
HardDrive's Avatar
This is the verbose output. It connects on 22.
Warning: Identity file pelicanboy/.ssh/LuckySevers.pem not accessible: No such file or directory.
OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011
debug1: Reading configuration data /etc/ssh_config
debug1: /etc/ssh_config line 20: Applying options for *
debug1: /etc/ssh_config line 102: Applying options for *
debug1: Connecting to 54.149.33.54 [54.149.33.54] port 22.
debug1: Connection established.
debug1: identity file /Users/pelicanboy/.ssh/id_rsa type -1
debug1: identity file /Users/pelicanboy/.ssh/id_rsa-cert type -1
debug1: identity file /Users/pelicanboy/.ssh/id_dsa type -1
debug1: identity file /Users/pelicanboy/.ssh/id_dsa-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.2
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.2
debug1: match: OpenSSH_6.2 pat OpenSSH*
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-ctr hmac-md5-etm@openssh.com none
debug1: kex: client->server aes128-ctr hmac-md5-etm@openssh.com none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Server host key: RSA 45:6c:b0:bb:36:b9:ea:62:e5:5f:13:5f:ff:bb:15:c5
debug1: Host '54.149.33.54' is known and matches the RSA host key.
debug1: Found key in /Users/pelicanboy/.ssh/known_hosts:2
debug1: ssh_rsa_verify: signature correct
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /Users/pelicanboy/.ssh/id_rsa
debug1: Trying private key: /Users/pelicanboy/.ssh/id_dsa
debug1: No more authentication methods to try.
2014 Cayman S, PDK
Old 04-27-2015, 03:03 PM
The Unsettler
What are the permissions on the remote key directory?
Are you the owner / logged in as the owner of the directory?
EDIT: looks like you are logged in as the owner, what are the permissions?
"Brandon Won"
Old 04-27-2015, 03:07 PM
Slackerous Maximus
HardDrive's Avatar
Bah, never mind. Fixed.
2014 Cayman S, PDK
Old 04-27-2015, 03:11 PM
Racer
winders's Avatar
Misspelled it as "LuckySevers.pem"?
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 04-27-2015, 04:19 PM
Scott R's Avatar
You need to import the key:
ssh-add -K /path/of/private/key
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-27-2015, 04:50 PM
