sleepy911's Avatar
Metal shop brands?
I'm looking to have a metal shop put in on my property (40acres). What brands do pelicans have and what do u like or would change. Looking to build about 3000 sf. I'm going to pay to have it put up and I'll do the finish work.
Old 04-10-2014, 08:09 PM
Registered Abuser
MT930's Avatar
Metal Building Manufacturers? IE Butler, Nucor ?
Or Metal Working Equipment Jet, South Bend, Miller Grizzly ?
What type of activities do you want do in it ?
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 04-10-2014, 08:19 PM
The Unsettler
stomachmonkey's Avatar
You mean a steel workshop.
When I read metal shop I think of Mr. T back in HS and his constant condemnation when guys were goofing off, "Hey, if you wanna play with something go play with yourself" as he pointed at the offenders with half a finger.
"I want my two dollars"
"Brandon Won"
Old 04-10-2014, 08:22 PM
No Band
futuresoptions's Avatar
Don't know if you have a Mueller in your area. I have purchased from them in the past, it is heavy gauge and has a 30yr warranty on the finish coloring alone...
He was a helluva plumber and his outfit was self explanatory
Old 04-10-2014, 08:34 PM
sleepy911's Avatar
Yes steel workshop. I want to use it as storage, then later as my home workshop. My goal is to simi retire in a few years and work from home.
Old 04-10-2014, 09:38 PM
MBAtarga's Avatar
Go over to garage journal and do some browsing/searching. LOTS of guys with metal building shops over there. It's probably very location dependent as well.
Mark
'83 SC Targa - since 5/5/2001
Old 04-11-2014, 07:26 AM
Nucor does good stuff - I don't know if they go as small as you're looking for.
The small (2400 SF or less) metal buildings I've seen around here have pretty uniformly been crap. CA building code and enforcement my help prevent that out there. I was shocked at the number of relatively new steel buildings that had roof failures around here this year. The snow was challenging here but it's not like we set a record.
In my experience I've seen much better built pole buildings than steel buildings. I don't know if that's an option out there.
I did a balloon frame on my shop (1900 SF) - but I designed and built it myself.
Old 04-11-2014, 08:02 AM
Registered Abuser
MT930's Avatar
+1 It all depends on size and budget. Under 3000 Sqft conventional slab on grade is the least expensive in these parts.
Morton Buildings has many options.
MT 930
американский
Old 04-11-2014, 08:11 AM
Also consider Rhino, Steel Buildings | Metal Buildings | Rhino Steel Building Systems
no experience with them, yet, but looking to have them quote a 40x60.
1960 356 Super 90 - EFI'd
1989 190e 2.6
1991 964
Old 04-11-2014, 02:57 PM
