least common denominator
scottmandue's Avatar
Anyone here hung a flat screen wall mount?
I like our new 51" flat screen on the low entertainment table at the far end of the room... I told my wife I didn't like the idea of a wall mount.
So tonight I am mounting the flat screen on the wall.
This is my question, when we opened the box and unpacked the flat screen all I got was a quick start guide and a flimsy stand... no hardware.
Screen has the standard 400x400 mount size.
Wall mount is being delivered today.
Would you presume the screws to attach the mount to the TV are going to come with the wall mount?
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 04-26-2014, 11:55 AM
yep. The one that I used to have came with a wide selection of screws for the mounting plate.
Old 04-26-2014, 12:04 PM
I see you
flatbutt's Avatar
Mine did. But I didn't like the anchor screws so I bought my own.
Old 04-26-2014, 12:10 PM
Should have everything you need. Make sure you mount it to studs! Otherwise easy to do.
2017 Toyota Tacoma TRD Sport(Hate it)
1965 Chevy Biscayne
Thanks guys!
I get home around 6:00 tonight and was worried about making late night runs to the hardware store.
I have a stud finder and all that.
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 04-26-2014, 12:41 PM
Yeah but she married you anyway! j/k
Old 04-26-2014, 01:32 PM
Student of the obvious
LeeH's Avatar
It's easy. Had our game room TV sitting on a stand. From the time my wife suggested I wall mount it until it was actually up there was about 45 minutes and that included a trip to Ace Hardware for the lag bolts. Having an extra stand in the garage didn't hurt!
Lee
Old 04-26-2014, 02:30 PM
It'll be legen-waitforit
stealthn's Avatar
Spend money on a good stand too, I did but it was for a 70" I was allowed to buy when we built our basement last year. Sadly I had already put backer board over the dry wall so I could put stone on the wall.
Took a little engineering to figure it out. I ended up cutting the backer board, drywall and using part of the same wood as the floor to create a square to mount the mount. The depth of the screws into the studs was the most important part....
Wall mounting is definitely the way to go and with bigger TV's I recommend the mount that can fully pivot out to get at the back without having to take it down each time.
Babble over.
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 04-26-2014, 02:44 PM
NeedSpace's Avatar
Speaking of. I am hoping to get a big honking flat screen for my basement and want to wall mount it as it will be a play room. My walls are a very old hard concrete (about 100 years old). I was thinking of drilling big holes, then cementing in anchors. Anyone see a problem with this approach? Is it overkill?
Old 04-26-2014, 02:46 PM
No, sleeve anchors. I like Hilti's products.
Old 04-26-2014, 03:13 PM
Bah dump... ding!
Zacty what I have... won't know the quality of the wall mount until I get home and see it but it is the type that pulls out... TV is going in the corner of the room so may want to angle it a bit, or not, won't know until I get it installed but we have some adjustably.
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 04-26-2014, 03:26 PM
I used this mount:
Amazon.com: Cheetah Mounts Plasma LCD Flat Screen TV Articulating Full Motion Dual Arm Wall Mount Bracket For 32-65" Displays Up To 165LBS Black With 10 Foot 1.4 HDMI Cable Fits Up To 24" Studs: Electronics
And these pass-through boxes for the wiring, so all the cables are hidden
Amazon.com: DataComm 45-0002-BK 2-Gang Recessed Low Voltage Cable Plate (Black): Electronics
Old 04-26-2014, 04:16 PM
NeedSpace's Avatar
OH! Great idea, then I wouldn't need to cement it in. Brilliant.
Old 04-26-2014, 05:03 PM
Platinum Member
dad911's Avatar
Don't cement in anchors, if you drill the holes too big, there is epoxy for anchoring to concrete.
However, I would use Tapcon screws. 1/4" Tapcons embedded in the concrete 1.5" are rated over 1000# each for pullout and sheer.
Old 04-26-2014, 05:22 PM
Tapcon are good too, but I would think washers are needed so the screw head will not go through the big holes on the hanging TV bracket. Cementing a bolt in existing concrete will cause the bolt to fall out. Its not if, its when.
Old 04-26-2014, 08:30 PM
NeedSpace's Avatar
I don't know why, but I have had hit or miss with tapcon screws. I don't know if it is the quality of the concrete or what. Some hold like no tomorrow, some are barely staying in.
Old 04-26-2014, 08:58 PM
Model Citizen
herr_oberst's Avatar
Thanks to this thread, today's project was hiding the tv cables. It was easy! Should have done it years ago.
Old 04-27-2014, 03:12 PM
Did you get the memo?
onewhippedpuppy's Avatar
I've had the same issue. Sometimes they blow out the hole so there's nothing to grab, even with careful pre-drilling. I tend to prefer using a Hilti gun or anchors.
‘07 Mazda RX8-8
Old 04-28-2014, 03:57 AM
mikesride's Avatar
Hung our 55" yesterday.....NOT a job to do by yourself!!!! That TV gets pretty heavy very quick! Why they don't make a "quick connect" system for mounting is beyond me!
I've driven alot of crap to get here man!
Old 04-28-2014, 06:30 AM
Band.
They do! These things are incredibly easy.
Dynex Wall Mount for Most 40" 56" FlatPanel TVs DX-TVM113 - Best Buy
Most articulating mounts you can also disassemble the arm into 2 easy pieces.
Installer error?
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 04-28-2014, 06:43 AM
