-   -   Two Six volt in series or two 12 volt batteries in Parallel for my RV House Power? (http://forums.pelicanparts.com/off-topic-discussions/809583-two-six-volt-series-two-12-volt-batteries-parallel-my-rv-house-power.html)
Hugh R 05-04-2014 09:02 PM
Took the big ass RV to Refugio State Beach north of Santa Barbara for the weekend. First time RVing without shore power. With judicious use of the house battery it was still draining the tiny house battery it came with, a tiny cheap battery and no marine duty.
I have a 5.5K generator in the unit, but can't run it from 8PM to 10 AM. In the morning the battery was so dead I couldn't start the generator without a jump. I need battery/generator to close the two slide outs.
I want bigger batteries to use an inverter to run the TV/Dish. A camping buddy who is an electrical engineer suggests two 6 volt golf cart sized batteries in series. He say you won't get more amps, but if one battery cooks a cell, the other battery won't try and power it and kill the second (good) battery.
Cost is around the same, like $250 plus or minus $50, so I don't care about the cost. Any thoughts on going either way?
ledhedsymbols 05-04-2014 09:43 PM
My gut says 12V in parallel.... I'd bet there is a device made to prevent the scenario you describe. You get no benefit I can see running 6V in series, but with two 12V you would get the full benefit of both batteries amperage ratings. I'll think about it more and do some research tonight and pay back again if I come up with anything else.
Drdogface 05-04-2014 09:51 PM
I have dealt with the same issue many times. It's all about amp/hours of various batteries. Most true deep cycle batteries are six volt and have higher total amp/hours than even so called deep cycle 12v. Having said that, your best bet is solar on the roof to keep them up during daylight.. Of course judicious use of power is a must, but you know that. I've always used Trojan 6v golf cart batteries hooked up right to make 12. If you have enough room run four in series/parallel fashion to double the available power and be sure to use thick enough connection cable..
ledhedsymbols 05-04-2014 10:13 PM
Interesting article, they recommend 6V in series.
RV Battery Basics
dad911 05-05-2014 12:14 AM
You can also use a Battery Isolator, it will allow both to charge off the alternator, but separate the usage. So the Aux circuits will not discharge the starter battery.
dennis in se pa 05-05-2014 12:17 AM
2 deep cycle gel cells for golf carts in series actually give you more power I was told. I have a mini home solar system setup using them.
You need a battery switch also, like is used on boats. Isolate the house batteries from the "start" batteries.
drew1 05-05-2014 03:27 AM
My thoughts kind of go the other way. I would go with 12V, the same size battery that cranks & runs RV motor vehicle lights fueul pump, etc. I would put 3 in sparalell if required. That way you would always have a battery to crank up and even if not a deep cycle, at least you could pick up one at any parts store.
74-911 05-05-2014 04:03 AM
If you have the room, use 2 - 6 volt deep cycle batteries in series for your house batteries and have a dedicated 12v for starting your genset. Use a marine 3 position switch ( 1-2-both ) to separate them. This is more or less the standard setup for larger sailboats with diesel engines where not being able to start your engine due to dead batteries can be a very serious issue.
fred cook 05-05-2014 04:38 AM
Battery drain
I used to have a conversion van that had a battery power interrupter system. If the battery voltage got to a certain point, it would disconnect the battery to prevent further drain. To start the vehicle, all you had to do was push a rest button. Another alternative could be to have two 12 volt batteries sitting side by side. when one goes flat, simply move the connectors to the second, charged battery. Third alternative, get a small very quiet Honda generator for use at night.
Battery drain
stealthn 05-05-2014 06:47 AM
Hugh,
First change all your bulbs to LED, it's expensive, but the savings in power is huge. Then get solar for you motor home and do batteries in line. Supposedly the 6 volt in line will cycle better than a single 12. There was an excellent write up on it somewhere I'll see if I can find it.
id10t 05-05-2014 07:26 AM
and maybe consider keeping a little lawn mower battery around to close slide outs or start your generator
Hugh R 05-05-2014 09:23 AM
Thanks for the input. I do have a battery shutoff switch, and I do have a small Honda generator (2000w), but I can't run a generator between 8PM and 10AM at most CA state parks. The solar panel is a good idea, I'll look into that. I only have room for two big batteries, plus the chasis battery under the hood.
I'll look into LEDs, I know some people who have done that. The biggest thing is to get the wife to turn off lights when on battery.
june82000 05-05-2014 10:38 AM
TROJAN Golf Cart Batteries. Two 6V batteries in series. The TROJAN's I currently have in mine are no-kidding 10 years old. No friggin' way that 2 12V batteries would have lasted that long. Just my.02.
porsche4life 05-05-2014 11:30 AM
Just go get a jump pack from harbor freight. With coupons you can get them for $39 and they are pretty decent. We have a few we've been using for several years.
Hugh R 05-05-2014 01:11 PM
Got a jump pack, I want to watch TV via DISH at night and not run the generator, nor have to depend on a jump pack to bail me out. The jump packs have been known to fail.
aschen 05-05-2014 02:08 PM
I think series combinations are generally better for batteries unless you can have giant issolating diodes.
With series you know there is no current flow when disconnected from the system. Parallel can have current flow between the batteries if they age differently or have naturally stronger cells.
rfuerst911sc 05-05-2014 02:29 PM
Two 6 volt batteries preferably Trojan brand and then install 200-300 watts of solar on the roof you're problem will be solved. If you are handy solar is easy to install once you get smart, all the info is on the web.
red-beard 05-05-2014 04:29 PM
Universal Power Group are the most cost effective deep cycle batteries.
That said, if space is limited, there are alternatives to lead acid.
Solar is cheaper than the most efficient small generator. A multiple approach, solar for general demand and generator for high demand is best.
All it takes is money.
Questions:
Will single phase 120 work or do you need 220?
Are you using Air Conditioning?
Microwave?
Put together a list of every electrical you have. Now look at total energy usage AND maximum demand.
Also, what are the dimensions of the available roof area on your camper?
Finally, how much do you want to spend?
Hugh R 05-05-2014 05:03 PM
120V, 50 circuits, but the only thing I want to run with batteries/inverter is the TV, DISH, move both slide outs, in and out, interior lights and water pump, and maybe heater fans (and propane). The A/C/microwave require the generator or shore power.
I wouldn't put big solar panels on the roof, about 200 sq. ft. as I need access to the roof via the back ladder for putting up chairs to watch the races if I want.
Looks like a decent solar panel, plus a control is spendy, like $400. I can buy a lot of gasoline for the generator for that, it uses about 1 gal/hour.
MBAtarga 05-05-2014 05:28 PM
Hum. What could you do with all that time being alone with the wife in the darkened interior RV?
red-beard 05-05-2014 06:26 PM
Solar Panels can be setup with legs. You set it up daily.
1 X 280 Watt solar panel $207. If you are OK with a CE Marked charge controller, 30A, $135. 12V - 250 Ah battery (3 kWh) $560. 1000 Watt pure sine wave inverter $350.
The solar panel can produce up to 2200 Watt-hours per day.
What size battery do you have now?
stealthn 05-05-2014 07:23 PM
Where are you getting 280W panels, nothing that high around here...
Here's a fun solar reference as well
http://www.samlexsolar.com/customer-support/pdf/Guides/RV_Solar_Power_Guide.pdf
Hugh R 05-05-2014 08:41 PM
Battery is so small it isn't to be considered at all. Like 225 cranking amps which is not even to be considered. I need new golf cart sized batteries.
stealthn 05-05-2014 08:58 PM
Here is a document with some info and diagrams on batteries in series or parallel, skip to chapters 8-9-10
http://samlexamerica.com/documents_solar/manuals/11020-SRV-100-150-30A-1013%20Lrez.pdf
red-beard 05-06-2014 04:37 AM
Sunelec
I have access to up to 385W panels. They are big! Usually, I use 180-250W panel.
Hugh, what size battery compartment do you have?
The design we're doing for the Gourmet food trucks is:
4-6 Solar Panels - 235W each (6 to 8 kWh per day)
4 x 3kWh batteries
3000W Pure Sine-wave inverter
MPPT Charge controller
The system does require the batteries to be plugged in at night. The solar panels extend the power during the day. This replaces a 2-3 kW gasoline generator, using about $100 of gasoline per week.
Hugh R 05-06-2014 09:14 AM
I'd have to measure the battery box, but about 18"x24" by 14 deep.
red-beard 05-06-2014 10:02 AM
The "big boy"
L: 20.47in (519.9 mm)
W: 10.55in (268 mm)
TH: 9.65in (245.1 mm) - Includes terminals
Weight: 154 lbs
http://upgi.com/Themes/leanandgreen/images/UPG/ProductDownloads/45964.pdf
3 kWh (12V x 250 Ah)
or with your dimensions, three of these would fit, 135 Ah, giving you 405Ah, or just under 5kW.
L: 13.39in (340.1 mm)
W: 6.81in (173.0 mm)
TH: 11.22in (285.0 mm)
Weight: 87 lbs
http://upgi.com/Themes/leanandgreen/images/UPG/ProductDownloads/40994.pdf
If the box is actually 28 inches long, 4 of them will fit giving you almost 6.5 kWh.
Hugh R 05-06-2014 10:15 AM
Interesting:
Thanks, how is their discharge and recharge life compared to a couple of six volt golf cart batteries in series?
The "big Boy" seems to go for $450 or more.
I think I can get two Trojan Golf Cart batteries for 1/2 that.
cstreit 05-06-2014 10:32 AM
Hugh I bought two 12 V deep cycle Optima blue tops for our coach. They aren't as good as the twin 6V's.... Don't last as long, don't seem to put out the amps...
Tilikum Turbo 05-06-2014 10:52 AM
Two six-volts in series amount to one 12 volt, as in two 12 volts in series amount to 24 volts.
Anytime you can place the batteries in parallel, you are in a win-lose situation, such as the two 12 volts in parallel.
Win is you have more cranking amps at start-up, and reserve when the alternator is not running. The additional battery also provides more stability(like a capacitor) across positive/negative to avoid power spikes and drops(which may not be too good for some of the sensitive circuits).
Lose is the alternator now has additional work required to maintain that level of charge when running, as well at start-up if the batteries are used when not running. At start-up as well, if not enough resistance is provided, you may cook the starter(or wiring to/from the starter) since an over-amperage could occur. This may be mitigated by a higher fuse rating for that circuit, but this really is only a band-aid approach.
My recommendation is simply buy the a single 12-Volt quality battery with the highest amperage rating that can be safely installed in that vehicle. The manufacturer or manual may give some insight to this.
I don't know why, but the spec battery for my 911 is giant...like a marine battery, but it fits, and works fine, and when it gives up the ghost, I'll buy something more modern.
Good luck.
red-beard 05-06-2014 11:03 AM
Originally Posted by Hugh R (Post 8051237)
Interesting:
I believe you'll find that 2 of the six volt batteries have 1/2 the capacity of the "big boy". The big boy is also AGM, so even if it cracks, it won't leak acid everywhere. Like a giant Optima.
The standard T-105 batteries are "wet-cells" which will need distilled water every once in a while. And they will need a place to vent hydrogen.
jhc 05-06-2014 12:40 PM
I put two 12 volt deep cycle in parallel in my Sprinter based class C with one slide. It was almost double the cost to buy 2 decent 6 volts. When I last camped with no hookup we just needed to turn on the power to run the water pump. Fridge, water heater and stove all run off propane. Keep the lights off and use a wind up powered LED lantern and just load up the ipad or laptop with entertainment before you leave the house and I showed full reserve on my house batteries in the morning.
stealthn 05-27-2014 06:20 PM
Revival,
While I wait for my solar panels to come in where the hell can I find a dual 12v battery box? I have a single now, but I want to move to a dual, but can't find one.
Yes I searched on goggle
