No Band
futuresoptions's Avatar
Question for Byron and other old school VW guys
If my memory serves me correctly, air cooled VW Beetle engines turn clockwise if looking at the crank pulley while running correct? Type IV engines run counter clockwise? Anyone know what direction Type III motors rotate while running?
"HEY A$$MAN!!!"
Old 06-01-2014, 07:37 AM
all of them clock-wise. corvair was CC-wise. if i remember right. people used to put them in busses and did something like flip the ring gear.
206 637 4071
Old 06-01-2014, 08:01 AM
Fast Acting, Long Lasting
John is correct. Corvairs turned counter clockwise, ACVWs all turned clockwise.
I think that Ed Iskenderian ground a cam for the Corvair that made it turn clockwise for VW transaxles, and you could always flip the carrier on the old swing axle VW transmissions.
I'm not sure what you'd do about the oil pump, starter, or fan on a reverse rotation, Isky-cammed Corvair though...Maybe Isky never made that cam I had heard about. Might be just a legend of old dune buggy lore.
Eighteen ways to burn fuel.
Old 06-01-2014, 09:29 AM
Geary's Avatar
Yeah, those corvair engines sorta ate up early VW transaxles, which didn't much like running in reverse rotation. Flipping the ring gear made the axles turn the correct way, but the coast side (of the pinion teeth) still had become the drive side, considerably reducing longevity.
Old 06-01-2014, 09:56 AM
resident samsquamch
sand_man's Avatar
Had many VW air-cooleds over the years. Type 1s to Type 111s. From memory, they all turned clock wise, as has already been pointed out. No experience with Corvair.
-jeff
Old 06-01-2014, 10:43 AM
No Band
Thanks for the help fellas!
"HEY A$$MAN!!!"
Old 06-01-2014, 01:06 PM
