Von,
Did you have to change that final gear to make one of your Unimogs to run at 65mph? |
stock they top out at 50?
so happy i peeked in on this thread before my wife put a parental lock on it..:D
Added some bling to the cab today. My buddy laser cut out a new grill out of 1/8" steel. Just had to cut out the old and weld in the new!
http://forums.pelicanparts.com/uploa...1407286537.jpg http://forums.pelicanparts.com/uploa...1407286557.jpg http://forums.pelicanparts.com/uploa...1407286577.jpg |
Put the cab on the chassis today to check clearances of turbo and to fit the air/water intercooler, heat exchanger and AC.
http://forums.pelicanparts.com/uploa...1407711188.jpg http://forums.pelicanparts.com/uploa...1407711209.jpg http://forums.pelicanparts.com/uploa...1407711226.jpg http://forums.pelicanparts.com/uploa...1407711258.jpg http://forums.pelicanparts.com/uploa...1407711285.jpg http://forums.pelicanparts.com/uploa...1407711329.jpg |
Sorry if you already mentioned this, but what is the popcorn material used for undercoating? My truck restoration needs something to kill sound and protect from rust. Did you have to go bare metal for that to work?
Finally got back to work on my own truck after all this time. I decided its time to finally finish my own truck! So I dropped off the cab to the paint shop, and welded up the 3-way dump box with a new bed star and 1/8" diamond plate steel floor. I added eight recessed 1 ton tie downs as well. Had to stretch the spider frame so it would dump out the back and weld in mounts for the dump cyl. Hope to have it done by June!
http://forums.pelicanparts.com/uploa...1490272696.jpg http://forums.pelicanparts.com/uploa...1490272696.jpg http://forums.pelicanparts.com/uploa...1490272696.jpg http://forums.pelicanparts.com/uploa...1490272696.jpg http://forums.pelicanparts.com/uploa...1490272696.jpg http://forums.pelicanparts.com/uploa...1490272696.JPG http://forums.pelicanparts.com/uploa...1490272696.JPG |
The grill is pretty groovy, did you find your intake doodad?
Been a while since I updated this thread. Didn't find my intake pipe before I made my own. Then finally did get one, but like the one I made better, so will be running that one. Got the cab and bed back from the paint shop. Had spray in bedliner done on both sides of the bed and the bottom of the cab and in the engine compartment. Now I am just getting the cab interior done before putting it on the chassis. As it is way easier to work on when its down low, vs being up in the air on the chassis.
http://forums.pelicanparts.com/uploa...1503837023.jpg http://forums.pelicanparts.com/uploa...1503837053.jpg http://forums.pelicanparts.com/uploa...1503837089.jpg http://forums.pelicanparts.com/uploa...1503837110.jpg http://forums.pelicanparts.com/uploa...1503837157.jpg http://forums.pelicanparts.com/uploa...1503837192.jpg |
I like what I see there...
Fantastic thread. Thanks for sharing.
Looks stout. Hard not to love a Unimog. Stellar restoration as well.
Jeez. I wish we were neighbors! That is coming along nice!
I've often wondered where Leland is with his FJ restoration. |
Gorgeous. We could use more Mogs in Houston right now.
Sent from my Nexus 6 using Tapatalk |
So if I want to drive one of these into the garage, will an 8' high door work or do I need to go to 9' ?
http://forums.pelicanparts.com/uploa...1503934164.jpg |
What do you mean "barely?" That is at least a few inches.
Barely clears is what the brake caliper does with the wheel on a "Jeep" autocrosser I saw last weekend. I think I could fit a business card between them. Von, your intake thing with the right paint on it would look perfect. That bed is the cat's ass man. |
