Home recirculating hot water heater
In our quest for a new place we have seen, in the colder country, homes with recirculating hot water systems, Is this something that can be easily installed in an existing home or from ground up, is it worth the cost?
I guess it depends how accessible your plumbing is. Can it easily be reached from under the house. Is it a one or two story house. Instead of on-demand-hot-water via recirculating hot water pipes you could think of installing local gas or electric "instant" tank less water heaters near sinks bathtubs and showers . Those are also overall better economically because you don't waste heated water when you don't need it.
Hot water for bathing or hot water for heating?
Dean,
It's usually pretty simple to add after the fact. The best case is to have your WH near the point of greatest use and run a loop to the furthest point. A small circulation pump can be put on a timer so you have instant hot water in all points during times of high use. Cost varies as it depends on how much copper you need and how accessible the plumbing is. I don't think it will pay for itself in water savings but the convenience factor is great. I recommend it as part of any remodel plan. |
How it works: http://www.fiainc.com/documents/6-10%20Domestic%20Hot%20Water%20Recirculation.pdf |
Hope this is helpful.
The Water Heater Payoff - Fine Homebuilding Article |
My water heater was relocated to outside the house when I re-piped 10 years ago, it was in a central closet inside the house with no emergency drain (duh). It takes 30 seconds to get hot water at the shower, I really don't worry about it. Sometimes, if I think about it, I water the indoor plants with the water waiting for it to heat up.
I have such a pump. Very costly on the electric bill. You circulate hot water, it cools in the pipes, you heat it again. Timer is a must.
thanks everyone, I just hadn't seen them before and thought they would be great, I have to wait quite a while for hot water to hit my shower and it isn't that far from the heater in the garage.
As we are living in an ever more water-scarce environment - dumping gallons and gallons of fresh water down the drain waiting for the hot water makes less and less sense.
In CA - our drought is the worst on record now - that 'extra' water isn't extra any longer! And it is going to get worse before it gets better.... The HW recirc loop makes a LOT of sense....ecologically. td |
In our small 3 bdrm/2ba single level home it takes ~20 seconds to get hot water into the showers (our biggest heated water consumers). Otherwise no issues. Showers are used 4x a day at different times. That's ~80 seconds of water down the drain a day. Water heaters are no longer cheap in SoCal - replacements even need permit/inspection. Crazy. When the time comes I'll look into a couple instant hot systems running electric.
If you do some searching you can do a gravity recirculation loop without a pump. That's a win win since you're saving water and not using electricity to recirculate.
I have a tankless and it takes a bit longer than I prefer for the water to heat up.
The unit is fine - it's just the distance. I'm not sure what I should or could do about it really. I don't think recirculating is the answer... More smaller units where I need the hot water might be but then I'd have 'hot water' modules everywhere... |
All copper here in Mich.
I wrapped all the basement pipes with foam/metal tape, and kept it off the cold concrete walls. About $1/ft. |
| All times are GMT -8. The time now is 04:37 PM. |
