-   -   Rear tire wear on my Cayenne GTS (http://forums.pelicanparts.com/off-topic-discussions/819527-rear-tire-wear-my-cayenne-gts.html)
TheRedSlantnose 07-06-2014 04:24 PM
First of all, I'm reposting this here from the Cayenne technical forum since user traffic is way too light there.
The rear tires on my Cayenne GTS wear down much quicker than the front tires for some reason. I bought all four new, high-quality Michelin tires at 53,000 miles, and now after just about 7,000 miles, my rear tires are already bald while my front tires have barely worn down. I went to a tire shop and then a local Autobahn Porsche dealer to have it checked out, and they both told me it isn't normal for those high-quality Michelins to wear down that quickly. The Porsche staff also informed me that excessive wear on the rear tires is common on GTS's because of the weight shift upon acceleration. The Cayenne is my wife's daily driver, and she normally does city driving, so the tire wear mostly not being caused by heavy acceleration in this case is just unusual. The possibility of being caused by wheelspin is also ruled out because having all-wheel drive, it just very rarely if ever happens with my Cayenne.
Any other ideas as to what may be causing my rear tires to wear down quicker, or has anyone else had this happen with their Cayenne?
Thanks,
stomachmonkey 07-06-2014 04:58 PM
You bought new tires at 53k so I assume you are not original owner?
Car now has 60 k on the clock so it's an 08'?
Take it in for a geometry check.
TheRedSlantnose 07-06-2014 05:25 PM
You guessed it, I'm not the original owner as I bought it back in late 2012.
No, mine's an '09, but you guessed the mileage correctly.
The Porsche dealer staff also noted the tire wear was completely even because the alignment was straight, and I had the alignment done rather recently during the winter of last year.
stealthn 07-06-2014 05:39 PM
Found the issue:
:D
Nostril Cheese 07-06-2014 06:04 PM
Cayennes eat tires. Especially the GTS.
They are a joy to drive though...
Just my two cents, but I've never seen Michelins last all that long anyway.
Arizona_928 07-06-2014 06:09 PM
I'll take a stab in the dark; launching at that those green lights?
Mike80911 07-06-2014 06:17 PM
I think you might have gotten the answer already with the weight shift. As stated Cayennes do eat tires. I have been told that is due to the weight of the vehicle so maybe they are right about the weight transferring to the back under acceleration. But 7K is really fast maybe the rear shocks are worn and it is adding stress to the tread on take off?
lendaddy 07-06-2014 06:27 PM
Weight shift my ass, 7k miles on a new set is stupid. Something must be misaligned (crazy toe out/in...something).
herr_oberst 07-06-2014 06:47 PM
Do you have a teenage son?
EarlyPorsche 07-06-2014 07:00 PM
You've got to have a crazy toe problem. Do the michelins have a tread wear warranty?
stomachmonkey 07-06-2014 07:01 PM
My GMC's weigh a bit more than a Cayenne and depending on brand of tires 10k a set is not abnormal.
TheRedSlantnose 07-06-2014 07:38 PM
Originally Posted by stealthn (Post 8151267)
Found the issue:
:D
She doesn't drive it "spiritedly" though :p
TheRedSlantnose 07-06-2014 07:41 PM
I doubt the shocks are worn, but my wife did lower the ride height a little with its air suspension since she's pretty short :p I guess it may be the ride height that's the problem.
TheRedSlantnose 07-06-2014 07:47 PM
No, because I said I got the alignment done not too long ago, and that the alignment is straight.
TheRedSlantnose 07-06-2014 07:52 PM
Yes, but even though he's 16, he doesn't drive :p
WPOZZZ 07-06-2014 07:55 PM
When you lower a vehicle, you usually increase the camber wear on the tires. On my E55, if I left it on Sport 2, it would eat up the tires.
herr_oberst 07-06-2014 08:02 PM
Or DOES he? Moohoohhaahaahah
http://forums.pelicanparts.com/uploa...1404705705.jpg :)
Dan J 07-07-2014 03:12 AM
Was the alignment done with the car lowered?
onewhippedpuppy 07-07-2014 04:02 AM
This is key. The alignment needs to be done by a good alignment shop at the ride height it is actually driven at. Make sure your shop knows what they are doing, all alignment shops are not created equal. Discuss your problem with the tech, it's possible they could reduce toe or camber settings in the rear to reduce wear. Does the GTS have more aggressive alignment settings than a standard Cayenne? If so, you might be able to have them align it to standard Cayenne specs for reduced wear. Just understand that may have to compromise handling for tire wear.
