-   -   Wind noise at speed -- whistling (http://forums.pelicanparts.com/off-topic-discussions/822478-wind-noise-speed-whistling.html)
john70t 07-28-2014 01:04 PM
Originally Posted by rusnak (Post 8186440)
whistling generally is caused by wind blowing over a hole or an air leak.
Originally Posted by CJFusco (Post 8182956)
...when I am driving at "highway speeds" with the windows down, there is a high-pitched whistling...
That is better then the Toyota Prius, which makes a pulsating "thud, thud, thud" throughout the cabin.
Any vehicle design is vulnerable to harmonic flaws at some point.
rusnak 07-28-2014 01:34 PM
^ The "thud thud" must come from the rear windows, correct?
john70t 07-28-2014 02:36 PM
Yessir. Feels like it's trying to pop out the rear window or eardrums.
onewhippedpuppy 07-29-2014 05:16 AM
How is the window to frame fit? You should be able to shut a piece of paper in the door between the window and weatherstrip, then not be able to slide the paper out. I believe the the window adjustment is the same as the 996, there are two plugs on the underside of the door that reveal two nuts mounted from below. You loosen the nuts and move the bottom of the window regulator track to adjust the window fit. Track moves out to move the top of the window in, vice versa.
