Bad wheel bearing--which side?
Vehicle-2007 Chevy Equinox
Miles-124000 AWD This weekend I noticed a hum in the front end. It SEEMS to be coming from the DS but I can't pinpoint it. I did replace the PS a few years so that helps with the diagnosis. Do any of you know a good way to confirm which side is the culprit? I tried the low speed turn test but the noise doesn't go away enough. Thanks,
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Turn right. Turn left.
When turning, which direction makes it go away? If you turn right and the noise is reduced, chances are, it's on the left. That's how I've awlays figured it out. Woops, you already said that.. comprehension, I guess. Lift the car, turn wheels by hand? Which one makes noise?
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
The Unsettler
Jack up the front.
Grab a wheel top and bottom. Rock it and look for slack, play.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Or spin it. They often sound bad even when just spun by hand...
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Usually when one wheel goes, the other is not far behind. Been burned before when I only replaced the bad one and not both.
You do not have permissi
Drive on the highway.
Pull over slow. Put the back of your hand on the hub center, or use an infrared thermometer. Hot=bad. |
Jack it up, get a good grip on the spindle/upright, and spin the wheel. You will be able to feel the vibration/roughness in the bad bearing. Compare it to the other side, and it will become 100% obvious which one is bad.
This method has never failed me When you are driving, it is usually the side opposite of the direction you are steering that is bad when you hear or feel the noise. Usually the side that has the vehicles weight loaded onto it . This method sometimes fools me however. Good luck.
No left turn un stoned |
Did you get the memo?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Lots of snow Porsche away
This is a pretty fool proof way to know for sure, a bad bearing makes for a very hot hub
76 911S 86 GMC K1500 78 XS750 cafe racer to be 79 XS750 because one is just not enough |
Dog-faced pony soldier
Had one fail on the Mercedes recently. Not fun. They get HOT before they fail (mine was badly discolored / blued and the grease was scorched badly). I suspect the IR thermometer method would be a good test without pulling the caps off and looking at things.
A car, a 911, a motorbike and a few surfboards Black Cars Matter Last edited by Porsche-O-Phile; 07-30-2014 at 02:12 PM.. |
Fast Acting, Long Lasting
I luv mah Chassis Ear!
Eighteen ways to burn fuel. |
Thanks guys.
I did the tests you suggested and it seems to be the DS as suspected. I'll get a new one and take care of business this weekend. I hate this vehicle but our plans don't have me getting anything new anytime soon.
FUSHIGI
If this is a hub bearing assembly that has been exposed to salted roads, consider having to take the upright off the car in order to accomplish replacement. I had to do that on the floor of my garage this past winter and it sucked...a lot.
Here's some help:
and this:
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde |
Thanks for the videos Oracle.
The one with the tire/wheel assembly is incredible. Mine is no where as bad as either one.
Information Junky
I know on my SC that it had a tick with each rev - but I could hear it only on new blacktop. Turned out to be a 2mm long 'scratch' in one of the two bearing races. --yeah, that's not going to make measurable heat, even tho' it was a failed bearing.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2˘ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
GRRRRRRRRRRRR
I started the job tonight after dinner. I had the assembly off and on my bench in about an hour. I didn't feel like trying to get the old hub out while attached to the strut. A little heat, a few blasts of PB Blaster PB and it came right out. I mounted the new hub and torqued the mounting bolts. Went to put it back together and the splines on the axle are too big for the hub. Sonofab........ They must have sold me the wrong assembly although I watched the guy pull it up on his computer. Back tomorrow and get the right part. Finishing the job won't take too long after that. I could have had this done tonight!!
Well, apparently the mid year change was the reason for the wrong part.
Whilst under the vehicle I noticed the driveshaft center bearing carrier was absolutely gone. I checked my service manual and set out to replace it. What a total PIA!! I gave up after abour an hour of fighting with the ujoints(clip type). I ended up taking the driveshaft to my local Tuffy and one the guys did the carrier replacement for me. You have to press the old one off and the new on. I gave him $20 and a box of donut holes for taking time out of his day for me. The cool thing was he let me help and showed me some cool tricks to getting stuck ujoints apart. Re installed the driveshaft and it's done. Now, I can wash the 911 and take it out for a drive.
