It should be called IPsuc..
Time suck. Only about 20 hours to get the clients configured and working...
But I now have the laptops and the Android tablets on IPsec VPNs |
How many clients? MSFT environment?
2 different clients:
NPC for the Android phones/tablets VPN IPsec client Netgear (Greenbow) Windows VPN IPsec client Once the configuration is working, installing on the laptops and tablets is a snap... |
Should have bought a Mac :)
Yeah. THAT is the problem... :rolleyes:
i love IPSec. Not a fan of SSL. But then my experience is all on Cisco routers and firewalls. I've got IPSec set ip on a cisco ASA at the house.
I'm sure Mikester will be along any minute. |
Sorry I've just never had that much of an issue, it is a standard, it's just his some companies deviate that causes issues.
That being said it's always best to contact the vendor and get their configs as it's usually been done before. |
Part of the problem, the NPC client can't be configured in the Android environment. You install the windows client on a PC. Get it up and running, then save the config file. this is then copied to the Android.
It is the only IPsec client working on Android with the Netgear Routers. |
I haven't been an IT professional since 1983...
Here I am!
Yep. I'm the VPN guy, well sort of... But James knows this and isn't using anything from Cisco for some reason. Personally I dig SSL and have had a ton of success with it over the years. |
Dude, 7.x code? Are you running a museum?
Dammit Jim! I'm an Engineer not a Network Specialist! SmileWavy |
So you're doing L2TP/IPSec or just L2TP?
Too lazy to set up a VPN... I just use SSH tunnels, or a remote X based application over SSH.
I'm doing straight IPsec. The Android devices have a combo L2TP/IPsec VPN function. They also have a PPTP function, but that quit working with my router after Honeycomb (Android 3.x).
I was using the PPTP server function for one of my remote workers, but it was unstable and would cause the router to reset a few times a day. So, I endeavored to persevere. I setup an IPsec client Policy and then worked on configuring the windows client. After that, I worked on configuring the NCP client. I used to buy "Cisco" stuff. But the "consumer" level stuff would quit working after about a year. And the "Cisco" VPN router I had would not work with my VOIP phone system. I am sure the commercial stuff works fine. But it is pretty darn expensive. Of course, 20 hours at $150-200/hr is pretty expensive too! |
| All times are GMT -8. The time now is 05:18 PM. |
