Gorilla
I look forward to your follow up. Best of luck! |
I want to again thank everyone for their input and interest. Especially Billy....who is always willing to help Pelicans with HVAC issues.
![]() So here's my followup on my AC issue.... Ended up ordering a new 2.5 ton condenser unit plus an inline Filter Drier from AC Wholesalers. Then I hired a local AC tech to do the install this morning. I had removed the old unit and had everything ready so he could braze on the 2 copper lines, wire up the electric feed (2 wires), and then fill with refrigerant. The cost ended up $866.00 for the unit and filter plus I paid the tech $300.00 for his time and the refrigerant so grand total was $1,166.00. I should be set for a while now - the condenser has a 5 year warranty but hopefully I will get 10 years out of it with proper maintenance. We'll see. It will be nice to sleep in my bed again instead of the living room couch! I must say though....having the 8K BTU window unit bought me some time to get a suitable plan and solution together. I'm hanging onto it just in case. Best $290.00 I ever spent! Here's a pic of my new unit.....
Old dog....new tricks..... |
canna change law physics
Looks good.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Thanks James and thanks for your help - you were the one who suggested just replacing the outside unit - which was the correct call.
B58/732
Glad you got things squared away without paying an arm and a leg.
Lucky you - we have a single one-piece unit...and mounted on the roof. When ours went out in June (!!) I had to buy a portable unit with a window exhaust and we all slept in the master bedroom. It was brutal.
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
UnRegistered User
Looks good.
One thing I am a little concerned with is if the unit recycles its heat being fenced in the way it is. One service call I had was that a 300 ton multiple compressor screw chiller was tripping on high pressure at startup -- sometimes. It was also tripping on high pressure during operation---sometimes. The installation was such that the air cooled condensers faced east for one circuit and west for another. Their was also a masonry wall that was to knock down the projected noise from the compressors and act as an architectural screen. The load from the rising and setting sun put on the condensing coils would drive the condensing pressure up by about 75 psi. When the wind conditions were right the hot air off the discharge would be pulled back into the inlet side of the condenser. This would result in a trip. The customer cut some windows in the brick walls and extended the fan discharge by adding round duct work to the outlet. When it was finished it looked like a brick ocean liner with holes in the hull.... So the point of this long post is to ask you to ensure that the condensers discharge hot air isn't being recycled back into the unit. It will drive up pressures, reduce efficiency and shorten unit life. You may need to check this under various wind conditions. A simple solution may be to cut out the lower sections of fence and install some chain link to allow easier air flow into the condenser. Always a pleasure to help out when I can.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. Last edited by billybek; 09-28-2014 at 05:49 AM.. |
Just thinking out loud
Hope it's ok to piggy back on this thread. My brother went the same route a few years ago with his old home, just replaced the outside unit. Being an a/c tech made me curious as to how long it would last. He sold the home shortly thereafter.
When a compressor locks up, and most scroll compressors do eventually, there would be bits of metal carried throughout the system, correct? Did the installer flush the lines and replace the orifice? It seems to me that it would be necessary to flush as there would be contamination of the oil, and possibly bits of debris remaining in the system if he just replaced the compressor/condenser and the in line drier. Also, just the same as R12, R-22 can be purchased with a license, however, neither are no longer are allowed to be manufactured in the US. That's why the prices have skyrocketed for both. It is total BS, both refrigerant are more efficient than the successor. Can't have it both ways, but with this you get neither. Less efficient refrigerants will require more energy to meet the desired outcome. So, what is worse, an energy plant emitting loads of pollution to keep up with demand, or a few molecules emitted into the sky. Question for the gurus. I have a 2.5 ton unit servicing about 1300 sq.ft, #71 orifice installed. I notice that when the temperature outside is higher, my vent temps are lower, eg. it's 80 out and vent temps are 60, when it's 100, vent temps are 55. Would it make sense to change the orifice? Hope you don't mind my post Baz.
83 944 91 FJ80 84 Ram Charger (now gone) |
![]() Quote:
Sounds like you are pumping in some nice cool air though.
UnRegistered User
Canada has set it's sights on HFC's like R134a for phase out just like many European countries. Goodness knows what will be next...
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
