Don Ro's Avatar
Steel wool - Sandpaper Grit Equivalent:
'Been doing some gun bluing lately...thought I'd share some Google searching:
I always thought that 0000 steel wool was finer than 400 grit - guess not.
No wonder I had to go back and hit it with 1200 grit.
4/0 steel wool = 400 grit sandpaper
3/0 steel wool = 280 grit
2/0 steel wool = 180 grit
2/0 steel wool = 120 grit
1 steel wool = 100 grit
2 steel wool = 60 grit
3 steel wool = 50 grit
4 steel wool = 36 grit
Anticipating the next question:
White Scotchbrite = 1200 grit (it has no abrasive)
Gray Scotchbrite = about 400 - 600
Maroon Scotchbrite = about 220-280
Green Scotchbrite = about 150 - 180
Be a little careful. Different manufacturers of non-woven abrasive material may be somewhat different.
The above is for 3M Scotch-Brite brand.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 09-22-2014, 11:51 PM
Originally Posted by NotaBRG View Post
This is great information and confirms why I shouldn't have used a green scotch bright to remove the tar from my rockers.
WD-40 and a paper towel will take off tar real easy, no scratches.
Old 09-23-2014, 05:47 AM
id10t's Avatar
One of the problems with steel wool is the chinese made stuff splinters super easy and can get embedded in wood, etc. if you are using it for spoonsmithing.
Check out the Scotch Brite pads -
Old 09-23-2014, 06:01 AM
Bill Douglas's Avatar
Thanks. I always thought a scotchbrite was just a scotchbrite.
I have some soft, worn out ones, for gun stuff.
Old 09-23-2014, 01:53 PM
Navin Johnson
TimT's Avatar
Also watch out for the different grading standards for Sandpaper..
HowStuffWorks "How does the sandpaper numbering system work?"
Or not all 600 grit sandpaper is equal..
I, of course learned the hard way... color sanding a fresh paint job on one of my cars.....
'69 911 GT-5
'75 914 GT-3
and others
Old 09-23-2014, 02:35 PM
Don Ro's Avatar
I'm bluing more gun parts - kinda fun, so I'm having a blast.
I have done a part to the point of 1200 grit...went to Autozone and got some 1500 and 1800 grit...just for yucks.
Wow! They had 3000 and 5000 grit there. Who knew? I guess for clear coat finishing.
Anyway, I also bought some 3000 just to see what it does.
Then I'll get to the bluing.
Don
Old 09-23-2014, 02:49 PM
Ha, I get it. Very witty.
Old 09-23-2014, 03:37 PM
Model Citizen
herr_oberst's Avatar
He's all fired up about his new hobby...
Old 09-23-2014, 03:46 PM
Don Ro's Avatar
Hey, retired and I love fixin' things. Lots to do around this place.
Also, got 3 SKSs and having fun w/them.
Now that I'm retired ('08) I don't know how I had time to do my own laundry when I had my business.
Bill Douglas - you're a sharp guy.
Don
Old 09-23-2014, 04:17 PM
Thanks I like to think so. The trouble is I'm about the only person at this stage that thinks that.
Old 09-23-2014, 04:24 PM
Double Trouble
targa911S's Avatar
what kind of bluing are you doing?
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 09-23-2014, 07:24 PM
Don Ro's Avatar
Cold bluing with Oxpho-Blue.
Got some tips, master?
Don
Old 09-23-2014, 07:28 PM
Double Trouble
targa911S's Avatar
Go for it. Are you using the cream or the liquid? The cream is easier to work with. The liquid it hard to control and best used for small stuff, screws and those kind of parts.Put it on with steel wool and an old tooth brush. Follow the directions closely. Card with 00 wool, 5 or six repetitions should get you there. Make sure you treat the parts with RIG or they will rust almost over night. You should try slow rust bluing. It''s easier than you think and MUCH more durable. I know you will figure this out yourself but fine grit is really over kill. polishing to 600 will do nicely.
* use nitril gloves** unless you want blue fingers from the cream. The liquid will absorb into your skin BAD STUFF.**
75 914 1.8
2010 Cayenne base
Old 09-23-2014, 07:40 PM
Don Ro's Avatar
Thanks, Dave.
I use gloves and cotton balls...am using the liquid. Got great results earlier on barrel and gas tube on the SKS.
The Oxpho -Blue is good stuff...many apps. and the blue is as black as the rest of the gun.
OK, I'll stop at 1500 grit...where I am now.
Thanks.
Your thoughts/opinions?...
Tried My Hand at Gun Bluing - A Little Bit...
Don
Old 09-23-2014, 07:52 PM
Double Trouble
targa911S's Avatar
Looks good! Well done..yes Oxpho is the best of the cold blues. Try the cream as well. Know that cold blues offer little protection though and you have to keep everything well lubed. Carry on brother carry on. when you are ready to try slow rust bluing drop me a line for some of the hot setups.
75 914 1.8
2010 Cayenne base
Old 09-24-2014, 06:43 AM
Don Ro's Avatar
Dave,
Do you have and use a damp box for your slow rust bluing?
If so, did you build one or buy one?
Don
Old 09-24-2014, 07:00 AM
Double Trouble
targa911S's Avatar
No I don't use one. My basement workshop is kept at about 50% humidity and it will rust them overnight. A rust box will hurry up the process. Simple to build. It IS called Slow rust blue though for a reason..LOL.
75 914 1.8
2010 Cayenne base
Old 09-24-2014, 07:34 AM
Don Ro's Avatar
You're a wizard, Dave.
I did find out. I ended up polishing the SKS receiver bolt cover to 1800 grit...and it didn't match the receiver...too shiny and nice.
I took it back down with 220...blued it and it's a much nicer match.
Don
Old 09-25-2014, 03:04 PM
Double Trouble
targa911S's Avatar
practice practice practice...
75 914 1.8
2010 Cayenne base
Old 09-25-2014, 03:26 PM
Don Ro's Avatar
Well, I guess that 1994 6 month course on personality profiling paid off.
Good to see that it was the outercourse and not the other course.
Don
Old 09-25-2014, 03:31 PM
