9 speed auto transmission ?
Just saw a commercial for a Chrysler 200 that has a 9 speed auto transmission ? Wow I remember when 5 speed auto's were the rage ! How time flies. So how complex are these when you get that many gears ? I assume more clutch packs/servos to go wrong ?
Often they are less complex as they are engaging the same ratios in two or three combos to make one 'gear'. Ford and GM have co-developed ten speed transmissions that will be out next year. At some point there is a diminishing return, but a wider spread (lower first, taller top gear) really helps both performance and fuel economy.
Why not just build a CVT? 8,9,10 speeds seems silly to me.... As in from a stop light the vehicle will shift thru 7 gears before I hit the other side of the intersection. Seems like that would get really annoying?
The only problem I can see is it is made by Chrysler.
What Nick said. What, exactly, is the practical difference between something like this and a CVT?
I was in a Chevy showroom recently and did a double-take when I saw the 7-speed manual in the new Corvette Sting Ray.
A car with this much torque, and it needs a 7-speed? I know it is probably a way for the car to meet fuel economy standards, but still... |
As many people already know, the design is in pursuit of fuel economy, but instead of saving a dime by simply using shorter gear ratios, they go ahead and build a transmission with more gears. I don't really get it either.
If transmissions continue to evolve this way, soon we'll have cars that have more gears than a semi truck :p |
The big three:
Form follows marketing |
My bmw 3-series daily driver has a 8 speed auto. It is really very very good.
Nothing wrong with it but I sure with the 4 speed in my truck was a 5 or 6 speed. Towing or hauling a load it hunts on hills more than I like, an extra gear or 2 would be nice.
Our 2012 A4 has an 8 speed auto, but it has a sport mode. I'm amazed at how what must be a pretty heavy car (I think 3600 pounds) can accelerate with a 2.0 turbo.
| All times are GMT -8. The time now is 05:31 PM. |
