When the box gets sluggish check for Spotlight indexing. Easiest way is to hit the magnifying glass upper right in the menu.
If not run Activity monitor, sort by %CPU, see if you have a process that's being a pig. Not a lot of difference between Parallels and Fusion. They've both been around long enough where sometimes a version of one is better than the other. Years ago I used Parallels but there were a couple of crappy versions and I switched to Fusion. Currently Parrallels has the advantage. VM Benchmarks - Parallels 10 vs. Fusion 7 vs. VirtualBox |
I've done the Activity Monitor thing, shows nothing, no hogging. I'll look at Spotlight next time it happens, thanks.
| All times are GMT -8. The time now is 08:18 AM. |
