Rust protect gun?
Suppose you were going to carry a blued steel gun in a way that assured it would get wet from rain and sweat. Just assume there is no way to avoid it. Is there something you would apply to the gun to reduce rusting? WD40? It isn't a valuable or vintage gun so you're not wigging out about it, but you'd like to protect the gun to the extent possible.
A good gun oil and a good wipe down at the end of the day should be sufficient. Whatever you do, do not use WD-40.
What Neil said.
I carried a S&W model 28 for years. A daily wipe down with Rem Oil worked well. Any holster wear that I encountered or any surface rust that I experienced from the elements, I would buff with a piece of kitchen scotch brite pad and then treat with a good quality cold blue and then re-oil it.
I'll add this as well, for some reason the blueing on air guns seems to be less robust than normal spoons. I have had to retouch them from just sitting in the safe. I have used a product called Corrosion X and it seems to have been working pretty good.
I use the Corrosion X as well.
The leather holster is also going to get wet. Treat with silicone or something else? I'm thinking of it trapping moisture against the metal.
Robar NP3.
Never use a leather holster if you know it's going to get wet. Get a cheap nylon Uncle Mike's or something.
Break Free CLP does a good job of protecting blued guns from rust. |
Anyone use Boeshield T-9?
I use it now and then...wipe it off well. |
I thought the color of Parkerized weapons used by the military came from their storage in cosmoline which changed the grey to light olive. Best Les |
The parkerizing can give different color depending on the actual chemical mix used, the metal being treated, etc. You'll also get color changes on heat treated areas. A nice coat of paint over all of it makes it all the same looking. |
All the oil choices above (-the wd-40) are good.
I'll only add Rig rag to the list. Very handy for daily wipe-down, which is probably the most important thing here. Take the gun out of the holster when not worn. Carter |
I also use Boeshield T-9. I use it on lots & lots of different things for lubrication & a bit of corrosion protection.
| All times are GMT -8. The time now is 01:39 AM. |
