-   -   '99 Jeep Cherokee not idling (http://forums.pelicanparts.com/off-topic-discussions/838679-99-jeep-cherokee-not-idling.html)
stuttgart46 11-14-2014 11:21 AM
My son has a '99 Jeep Cherokee with the inline 6 that is acting a little funky. From time to time it will die at idle. As long as I have the revs above idle it's fine. And once it warms up it does fine. Do you guys think this is a fuel pump or fuel filter issue? I do not have a gauge to determine fuel pressure.
Thanks in advance for the suggestions.
Oh Haha 11-14-2014 11:25 AM
Check engine light on? If so, read the code or codes to get a starting point.
Short of that I would try cleaning the MAF sensor, if equipped as well as checking for loose broken vacuum lines.
Air filter clean?
EDIT--I did a search on the web and found that it COULD be the Idle Air Circuit sensor.
flipper35 11-14-2014 12:02 PM
Throttle position sensor dirty?
fastfredracing 11-14-2014 12:08 PM
First place I would look is on the side of the intake manifold, there two vacum lines that are connected there, and I see them leak all the time. I think there are 90 elbows on them that lead to plastic tubing, but you can easily cut them off, and make a repair with straight vacum tubing .
If no vacum leaks are found, I would check, and clean the throttle body, then re set all adaptives . Not sure, if you can do this without a scanner, but , after you clean the throttle body, maybe try disconnecting the battery for 10 minutes or so, and then let it re-learn how to idle.
Keep us posted, this should be an easy one.
Aragorn 11-14-2014 12:49 PM
I had a 99 Grand Cherokee Laredo with 4.0l that had a similar problem. Would not start without keeping foot on gas and would not idle. Throttle position sensor was bad.
Usually a dying fuel pump can be temporally corrected by banging on the fuel tank with a rubber mallet (near the fuel pump location.) Dying fuel pump is usually precipitated by a more persistent louder whine from the pump. Clogged Fuel filter will usually not clear itself up.
stuttgart46 11-14-2014 12:57 PM
Thank you guys.
I'll try it out this weekend and let you know how it goes.
Dansvan 11-14-2014 01:04 PM
Also clean the throttle body. Gunk builds up around the butterfly and the IAC motor cant keep up at cold idle.
Don Ro 11-14-2014 10:12 PM
NAXJA Forums -::- North American XJ Association - Powered by vBulletin
Threads: 301,568, Posts: 3,691,870, Users: 78,592
Arizona_928 11-14-2014 11:31 PM
Every XJ that i have owned would stumble the idle once idling for longer then 5 or so mins. Very common.
I would replace the fuel filter as they are only 10 bucks at napa.
EarlyPorsche 11-15-2014 07:08 AM
Clean throttle body. Make sure you get no fluid into IAC and TPS. Most likely need a TPS as well but you can try cleaning IAC area well. CPS can cause stalling but not only at idle - it would happen all over the powerband but mostly when hot and no airflow (idling). CPS failure would be my second guess with first being TPS.
stuttgart46 11-15-2014 04:43 PM
Cleaned the throttle body and IAC. So far so good.
It was pretty dirty.
Thanks again for all the input. I really appreciate it.
john70t 11-15-2014 11:47 PM
Open loop is where the problem is.
Old school.
