I like Numbers better anyway. Excel is pretty robust but I find Numbers more intuitive and easier on the eyes. Far easier to tweak the look of too.
I have to say the Air is the best laptop I've ever bought. I'm out of space so I think I'll buy another newer one. Unix, Mac OS and when I need it Parallels.
Got way too many devices but I can akways use more :) Been through a lot of PC's and laptops but my Apple products always and still work. Still have a working SE/30 and Newton :D |
rjp |
Something I don't like about Macs is that they have two names for their OS. One app says it needs OS 10.9 and another says it needs Mavericks. I'm constantly looking up which number relates to which name because I can't ever remember. Is their any good reason for this?
This talk of upgrading the mac book has me taking notice.
where do I look in the computer to check hard drive and ram? |
Depending on which version of the OS it'll be either "More Info" or "System Report" RAM and hard drive are in the Hardware category. RAM is obvious, Memory Hard drive depends on the machine, either under ATA or SATA. Look for Rotational Speed. It'll be either 5400 or 7200. If a much older box could even be 4800. |
Here is what I have.
Model Name: MacBook Pro Model Identifier: MacBookPro6,2 Processor Name: Intel Core i5 Processor Speed: 2.53 GHz Number of Processors: 1 Total Number of Cores: 2 L2 Cache (per Core): 256 KB L3 Cache: 3 MB Memory: 4 GB Processor Interconnect Speed: 4.8 GT/s Boot ROM Version: MBP61.0057.B0F SMC Version (system): 1.58f17 Serial Number (system): W8015V2ZAGV Hardware UUID: 94F7F446-9324-5DB0-8DCB-7FF70AD29684 Sudden Motion Sensor: State: Enabled 5400 rotational under Serial ATA Intel 5 Series Chipset: Vendor: Intel Product: 5 Series Chipset Link Speed: 3 Gigabit Negotiated Link Speed: 1.5 Gigabit Description: AHCI Version 1.30 Supported Hitachi HTS545050B9SA02: Capacity: 500.11 GB (500,107,862,016 bytes) Model: Hitachi HTS545050B9SA02 Revision: PB4AC60W Serial Number: 101126PBL400M7GMKP0V Native Command Queuing: Yes Queue Depth: 32 Removable Media: No Detachable Drive: No BSD Name: disk0 Rotational Rate: 5400 Medium Type: Rotational Partition Map Type: GPT (GUID Partition Table) S.M.A.R.T. status: Failing Volumes: disk0s1: Capacity: 209.7 MB (209,715,200 bytes) BSD Name: disk0s1 Content: EFI Macintosh HD: Capacity: 499.25 GB (499,248,103,424 bytes) Available: 110.68 GB (110,677,479,424 bytes) Writable: Yes File System: Journaled HFS+ BSD Name: disk0s2 Mount Point: / Content: Apple_HFS Recovery HD: Capacity: 650 MB (650,002,432 bytes) BSD Name: disk0s3 Content: Apple_Boot |
nuthin outlandish. 2011 MBP13" Best computer I've ever owned and the first time in my life I'm not itching to upgrade after a few years. I'm attached to this thing like my right arm.
Model Name: MacBook Pro Model Identifier: MacBookPro8,1 Processor Name: Intel Core i5 Processor Speed: 2.3 GHz Number of Processors: 1 Total Number of Cores: 2 L2 Cache (per Core): 256 KB L3 Cache: 3 MB Memory: 4 GB Boot ROM Version: MBP81.0047.B27 SMC Version (system): 1.68f99 Serial Number (system): C02FJ553DH2L Hardware UUID: E5021AB5-C345-546E-8A71-50D5BBAB85DB Sudden Motion Sensor: State: Enabled |
I would do full back up ASAP. That box will take 8 GB RAM max. |
Man, I need to step up & go to the Dark Side...
I felt the same way when I got my first Macbook in 2011. Never have things been so easy. Still running strong with no issues, even after years of continuous use.
A 2011 MacBook Pro can take 16 GB of RAM, not just 8 GB like Apple's literature claims. Ask me how I know. ;)
Chocolatelabs is mid 2010. He needs to address that hard drive issue. As long as he's in there may as well do the RAM. |
Back it all up throw more ram in it and add an ssd, and you will feel like you just bought a new computer...
When I look at the drive section there are 2 chip sets. Below is the other. Maybe its the original. I have replaced this hard drive once. Backing up now. ntel 5 Series Chipset: Vendor: Intel Product: 5 Series Chipset Link Speed: 3 Gigabit Negotiated Link Speed: 1.5 Gigabit Description: AHCI Version 1.30 Supported MAT****ADVD-R UJ-898: Model: MAT****ADVD-R UJ-898 Revision: HC09 Serial Number: UJ92 1258R2 Native Command Queuing: No Detachable Drive: No Power Off: Yes Async Notification: No |
where you guys getting the best deal on power bricks? I'm down to only one- the pins always fail- they go flat....
I just "upgraded" my tower to Yosemite. I needed it to run a new program (I guess it dates you when you still call "apps" programs) that required Yosemite. I'm not fond of the new look. Other than that it seems OK. I think I'm going to like how it interacts with my phone and iPad.
Mac Minis and Airs from 2011 and on MacBook Pro and iMacs from 2012 and on MacPro only the new one from 2013 and on Handoff will not work on anything older Have in my list to add a BT 4 USB dongle to see if it'll work just have not been that motivated yet. |
There is a local Mac repair shop here in town.
If I bring the computer there for hard drive swap and ram upgrade what should I expect to pay in labor? PS-thanks for the help on this |
My MacBook is just a bit too early to support it but I'm not disappointed. In my experience Bluetooth generally sucks (not just on Apple devices). It works fine between my iPhone and hands-free in the car but for everything else supposedly "Bluetooth comparable" it seems to have all the reliability of a 1978 Oldsmobile.
Hard to say what they would charge.
You'll likely pay a premium for their RAM and hard drive plus labor. Whereabouts is "here" |
Just got mac book back
Rockin 8 ram and 1 TB Without this thread I would have likely awaken one morning to find everything lost. Thanks |
Scott is God...
Scott, Can you give me an opinion here? Mines been a bit sluggish of late now that I am running outlook365. Thinking I could use a bump in ram. 8gb? or go all the way to 16gb?
Model Name: MacBook Pro Model Identifier: MacBookPro6,2 Processor Name: Intel Core i7 Processor Speed: 2.66 GHz Number of Processors: 1 Total Number of Cores: 2 L2 Cache (per Core): 256 KB L3 Cache: 4 MB Memory: 4 GB Processor Interconnect Speed: 4.8 GT/s Boot ROM Version: MBP61.0057.B0C SMC Version (system): 1.58f17 ECC: Disabled Upgradeable Memory: Yes BANK 0/DIMM0: Size: 2 GB Type: DDR3 Speed: 1067 MHz Status: OK Manufacturer: 0x80AD Part Number: 0x484D54313235533654465238432D47372020 Serial Number: 0x0C4212B7 BANK 1/DIMM0: Size: 2 GB Type: DDR3 Speed: 1067 MHz Status: OK Manufacturer: 0x80AD Part Number: 0x484D54313235533654465238432D47372020 Serial Number: 0x0C8212E2 Capacity: 500.11 GB (500,107,862,016 bytes) Model: Hitachi HTS725050A9A362 Revision: PC4ACB1E Serial Number: 101116PCG420VLKVGX0C Native Command Queuing: Yes Queue Depth: 32 Removable Media: No Detachable Drive: No BSD Name: disk0 Rotational Rate: 7200 Medium Type: Rotational Partition Map Type: GPT (GUID Partition Table) S.M.A.R.T. status: Verified |
Sid,
You've got the faster drive but it's only 500 MB, how full is it? They get fussy as you approach 90%+ capacity. You can put 8 GB in there which will help. One thing you can also grab is this https://fiplab.com/apps/memory-clean-for-mac Let's you monitor RAM usage and purge memory cache that does not clean itself. It's free and sits up in the menu bar so you can always see what's going on. I run it on all my machines and it comes in handy. |
How's it run? |
Certainly starts faster when I power up. I am running yosemite now which a little different than the version I was running. Now I need to find a good 1TB back up drive. |
No, you need a good 3TB backup drive ;-)
Anyone looking to do the 16 GB upgrade, Mac or Windows box, there is a smoking deal on Newegg right now.
$119.99 out the door. That is a great frikkin deal. Mushkin Enhanced Blackline 16GB (2 x 8G) 204-Pin DDR3 SO-DIMM DDR3 1600 (PC3 12800) Laptop Memory Model 997067 - Newegg.com |
Just bought, should be here in 3-5 BD...Thanks Scott!
My HD is very full. I purge stuff every few months, but I still think a bump to 1tb would prolong the life of this computer. What would you recommend? Quote:
Whatever you get make sure it's 7,200 rpm or better. 10k RPM drives are available but they are spendy and capacity is lower. HGST Travelstar 7K1000 HTS721010A9E630 (0J22423) 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 2.5" Internal Notebook Hard Drive - Newegg.com |
Anyone have a Mac Book Pro they want to trade off??
Go SSD if you can afford it - I7 with 8G RAM and SSD =superfly
It's no Air though ;) |
| All times are GMT -8. The time now is 03:41 PM. |
