Subaru Forester fuel leak. My solution: Comments or Ideas?
My Subaru Forester winter "beater" is leaking fuel. It's the return line. As luck would have it, the leak is in a place that is inaccessible....you have to drop the tank to get to it. I don't want to drop the tank. So I was thinking of the following solution:
There is room to add in a new fuel line (125 psi injector line) directly from the pump and snake it though and attach it to the accessible area of the hard lines. I don't see any issues, though maybe in my annoyed state I'm not thinking this all the way though. I've included pictures of the areas in question. Is this is viable solution? ![]()
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot.... |
Almost Banned Once
What I would do is drop the tank and replace the line. Painful but worth it IMO.
Your solution may work fine but I really don't think it's a good idea to modify the fuel system in any car.
- Peter |
I'm not modifying it per se. The original line runs from fuel tank to fitting anyways. The car is a winter beater and has seen salted roads since 1998. I'm not sure if any of the bolts would even come off (or might break off) in trying to remove the fuel tank. Lots of effort and potential problems for a mere fuel return line on a beater. To me, it came down to "risk vs reward". But thank you very much for your reply.
Hell Belcho
If its just the return line, I dont see any problem. If you end up cutting the hard line, make sure you double hose clamp it. Or if there's room, flare the end of the line.
Saved by the buoyancy of citrus. |
Excellent advice. Thanks!
Almost Banned Once
You're welcome but how do you know the return line is the only line with any issues?
I don't mean to be pedantic but it is fuel after all.
- Peter |
Because it's the only line that's leaking...
Lots of snow Porsche away
Right now, though it is just about a certainty one of the others will be soon...if it is the hard line area that is leaking it is most likely a corrosion issue, maybe abetted by chaffing or more likely dissimilar metal at a clamp location. All the lines are the same material most likely, in the same location and conditions. If you fix the one it will be good practice for doing the others though...
76 911S 86 GMC K1500 78 XS750 cafe racer to be 79 XS750 because one is just not enough |
What year is your Subaru? Have you researched recalls?
I did run a Chevy cavalier for about a year and a half bypassing the factory lines from the tank all the way to the firewall with no issues so I don't see any safety issue with your plan, as long as you route the line sensibly and secure it well.
Recalls? It's a 1998
I'd be surprised if there were any.
If you gave this car to a mechanic, and he told you what you proposing as a fix, that he was going to do that...would you give the green light? I would look at the guy and say...are you ****** crazy? Do it RIGHT...this is gasoline, not orange juice running thru these lines. VERY prudent to do the other rubber lines while your there...everyone of those is suspect at this point with all that salt, etc, and maybe even spray a little clear-coat afterwards to keep that salt at bay(or slow down the process of corrosion)
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!) 1996 Toyota Corolla(der 'clapper') |
However, he did say it would be a problem for him if it was the high pressure/feed line.
Hell Belcho
I found that amusing also. Your idea will work fine . Id also get the correct style high pressure clamps . You will more likely than not, damage other lines in the process, so be prepared to open up a small can of worms, and have supplies on standby to repair the pressure, and vapor lines .
No left turn un stoned |
Control Group
Coolant hoses are probably suspect if they are the OG stuff too.
She was the kindest person I ever met |
I suspect he will have a very low chance of a fire. In Windsor. In winter. It will be covered in wet salty water 90% of the time....
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Gary H 1978 911 SC
Check RE-Calls I had a 05 and remember something about corrosion and leaky fuel lines being Re called
Gary H 1978 911 SC |
D idn't E arn I t
I know it sux, but if you're planning on keeping it, drop the tank. Reason being the others aren't far behind, the one you're fixing is just the 1st one across the finish line. You will have to address it soon, and probably start another leak somewhere else touching it anyhow.
Unless, cars rust differently in CA vs USA ![]() rjp
AOC/Hogg 2028 |
I went through the recalls and nothing helps him there, the only fuel line recall was on the legacy and outback models in 2003 or somehting.
