-   -   What happens when an engine has too much oil? (http://forums.pelicanparts.com/off-topic-discussions/845707-what-happens-when-engine-has-too-much-oil.html)
John Rogers 01-07-2015 05:57 PM
Sammy, the info about the Bon-Ami is true. When we used to race a small block Chevy in the "D Gas" drag racing class that was how the rings got seated quickly. It had 14.5 to 1 compression ratio so it needed all the help it could get! The Milford Delaware dealer where the owner of the car worked had done this a few times. I think it not needed any longer as ring material has greatly improved as well as no carbs that dump fuel while the engine is cranking.
Scuba Steve 01-08-2015 04:37 AM
Good call on passing on this one. The two problems may not have been related, but if they were...
