-   -   Basement project: Next Steps (http://forums.pelicanparts.com/off-topic-discussions/850773-basement-project-next-steps.html)
legion 02-08-2015 06:16 PM
I'm pretty much done with framing and electrical in my basement. The walk-out basement was all framed except against the concrete walls.
There is no insulation in the basement, either against the concrete or exterior walls. My original plan after getting to this point, was to get closed-cell spray foam installed on all of the outside walls (against concrete and exterior).
I'm thinking it may be better to have the copper for the downstairs bathroom run before the spray foam. My concern is soldering the pipes with the foam inches behind them.
Any advice from the contractor/plumber types?
billybek 02-08-2015 07:00 PM
I had to run a chase wall to run piping in to keep them away from freezing conditions. I would imagine that in GA you probably don't have to worry about that!
I was dead set against running plastic lines for the basement bathroom but simply ran out of time and hired one of my former students to rough in the pex. Way cheaper and I hope just as long lasting.
VincentVega 02-08-2015 08:39 PM
Curious why you want to use copper. Either way I would do insulation just before drywall.
whiskyb 02-09-2015 06:17 AM
Pex is way better and very diy. Easier than copper and no (small) chance of leaks
legion 02-09-2015 12:04 PM
Can I run Pex off of the existing copper that feeds the rest of the house?
porsche4life 02-09-2015 12:09 PM
Yes. Just sweat a pec connector onto the copper and then you are off to the races. They should have what you need at any home improvement place.
VincentVega 02-09-2015 12:34 PM
http://www.doityourself.com/forum/at...02_pex_009.jpg
A sharkbite would work also.
porsche4life 02-09-2015 12:44 PM
I used a couple of sharkbites to go from copper to Pex, and honestly if soldering was an option, I'd go that way. They aren't leaking but I haven't covered that hole in the wall yet either.
DanielDudley 02-09-2015 01:58 PM
Most would prefer a soldered joint, but the shark fittings don't have an o ring but a ring seal that actually seals better as pressure is applied to the seal. They are costly because they are well made, and have been around for quite a while, as has PEX.
Both have a good track record.
LakeCleElum 02-09-2015 03:36 PM
Leaks big time when rodents nibble on it....According to an insurance adjuster I know....
VincentVega 02-09-2015 05:20 PM
That's pretty common, but they work. The 'old' way of thinking is hard to change, I usually a leary of anything but the old way. Done properly either works.
Brian 162 02-09-2015 06:11 PM
I heard the same thing from a plumber. Mice love chewing pex pipe. I've used pex piping a few times. It's much quicker to use but you need to support it more.
I prefer to use copper.
whiskyb 02-10-2015 06:54 AM
Never heard of the rodent issue and I have installed it in many barns and farm houses. Around here the critters chew the wiring.
LWJ 02-10-2015 07:10 AM
Check your Pex connectors. They are not all the same. Cheap ones leak. Some brands (Uponor) have a 25 year warranty if installed by factory people. I have had some large claims with pex products. It is not perfect.
