Make sure you know your radio and Nav codes before disconnecting the battery....
These little issues aside, I still want a Cayenne Turbo.
The newer Porsches all have a fiber optic network, the codes are internal to the units and modules. Only a pain if you have to replace a radio, then you have to have your dealership code the radio to the module.
Really the battery placement is nothing crazy. How many cars have their batteries out in the open? I've had multiple cars with trunk mounted batteries, under seat mounted batteries, batteries hidden under crap under the hood, etc. Easy maintenance is a thing of the past. |
G |
No kidding. I'm still perplexed how the hell you get the battery out of my new escape. http://tapatalk.imageshack.com/v2/15...41ebb2d15a.jpg It's under the black box next to the firewall behind the brake booster! I guess you disassemble the intake? |
So....your battery is dead, and the first step is to move the electric seat controls in order to access same said battery??? Is there a manual override to move the seat?:confused:
We've gone through a battery every two years on our Cayenne. Porsche told me it's because the car largely sits unused. But when it's starting to go weird things start happening with the security module, and the dashboard display. It starts with the security module setting itself to "honk" when armed when I normally have it turned off.
On mine the seat just unbolts in the front and folds back...
Got it back,
Feels much better at start up. Starter working fine. H9 size battery should you ever need one. |
900 Cold cranking Amps (1000 cranking Amps) ***. 150 Reserve minutes. Warranty consists of 3 years free replacement plus 2 years prorated. This is only the second battery since new in my 2004...but it is a daily driver. |
I guess that's what we call progress? |
Lesson learned, don't let the 986/996 get low on battery!
| All times are GMT -8. The time now is 06:01 PM. |
