-   -   Question for the electrical engineers and gurus (http://forums.pelicanparts.com/off-topic-discussions/855500-question-electrical-engineers-gurus.html)
afterburn 549 03-10-2015 07:28 PM
Which Batt if any in a two batt system like on a diesel pickup (two batt in parallel )
Should be used to jump a single batt vehicle?
I say it does not matter.
Others say it does.
I can not find a technical write up anywhere.
I have jumped many vehicles and never payed any atn, to which i hooked up to.
Your thoughts?
pete3799 03-10-2015 07:34 PM
Doesn't matter.......either one will provide 12 volts.
afterburn 549 03-10-2015 07:36 PM
I understand that.
VINMAN 03-10-2015 07:54 PM
Doesn't make a difference.
Gogar 03-10-2015 08:06 PM
The one that's closer will provide .000000000000000001% better performance.
afterburn 549 03-10-2015 08:09 PM
I guess the stupid in the argument is that the alt wire is on one side, not both.
I think the answer is there is no correct answer, which is what i thought.
Gogar 03-10-2015 08:14 PM
You could totally calculate the voltage/current drop in the length of cable that is farther away from the alternator, if you knew the properties of the cable used in the construction of the vehicle. :) I just did a quick mental calculation based on the knowledge I acquired from my Bachelors of Music.
afterburn 549 03-10-2015 08:16 PM
It cant be worth the effort....LOL
red-beard 03-10-2015 09:14 PM
If they are truly in parallel, there should be no difference. They are both are used to turn the starter and should be balanced, or one will die before the other. The same is true for charging.
Besides, with a diesel truck, the alternator is usually an extra heavy duty. I doubt you will be pulling current from anything except the alternator. Most battery cables should be used to CHARGE a battery, not try to start a car.
beepbeep 03-11-2015 12:29 AM
Doesn't matter...the battery that is further away from jump cables will provide slightly less amperage due to miniscule voltage drop across the cables that is connecting it to another battery...that's all.
Jim Richards 03-11-2015 04:58 AM
Doesn't matter.
john70t 03-11-2015 06:03 AM
Voltage= Amperage x Resistance: https://en.wikipedia.org/wiki/Ohm%27s_law
Batteries in parallel stay 12V but the amps available double(assuming both are same).
If one drops it gets refilled by the other.
Considering that most of the resistance is in the discharged battery and it has a much smaller mass and electrical potential than the two in the truck, any resistance in the cables/connection should be negligible.
The limitations are in how fast the dead battery will accept new electrons.
Resistance does play a larger role at higher voltages, but this is only 12V.
mreid 03-11-2015 06:09 AM
Doesn't matter, but I'm real curious as to the reasons given by those who say it does.
What reasons do they give so we can laugh at them?
afterburn 549 03-11-2015 08:11 AM
Some stupid idea about the alternator charge wire is going to one battery or the other.
Its a elementary thought as thats not how the systems charge anyway (unless your name is Lucus ) LOL
Outback Porsche 03-11-2015 08:30 AM
It's all about how the smoke fills the batteries. The one closest to the alternator fills first, then when it's full it spills over into the next battery, and so on. You won't be able to use the battery connected via the jumper cables to start anything unless it is full of smoke first.
mreid 03-11-2015 08:58 AM
This should help:
http://forums.pelicanparts.com/uploa...1426089479.jpg
