You need to find a different dealership.
It's probably just a exhaust gasket leak due to broken manifold studs. Couple of hours (worst case - stud extractor) and it will be fine. |
My broken studs have sounded EXACTLY like every bottom end knock i've had or heard. Its nuts to think but the stud from the dealer was like $10 and fixed everything.
There was a 1 or 2 year only twin plug 4.7 actually. Not real common but it was out there. They made a second iteration of the 4.7 then with the economy and car industry cut it out and kept it simple with the 5.7 being the only V8. |
You could be right about the twin plug 4.7L. I don't know really. I know the engine was in several other Chrysler products as well. I just assumed since the Hemi was a twin plug the 4.7 wouldn't be.
The sound I hear definitely isn't as loud as rod knock sound but loud enough to get my attention when the engine is cold. It sounds to me like it is coming from the top vs. the bottom and it quiets down as it warms up. My first step is to get the studs repaired. Then get a second possibly even a third opinion on the tapping sound. I will move forward from there. Thank you all again for the input. As usual this forum is awesome with great people. I posted on the Jeep Commander forum a day before posting here. I have only received two replies on that forum. I just assumed people would be as eager to jump in over there as they are here. A person can get spoiled hanging around here. |
So I took the Commander to a local Jeep dealer for diagnosis. There were a few days between the time I took the Commander from the old service station and my appointment date at the dealership last Thursday. I drove it during that time to listen to the engine run to see if anything changed. I hear the same tapping sound as before, no better no worse. The tapping slowly quiets down as the manifold heats up. I desperately tried to hear sounds from the bottom of the engine to validate the old stations claim. Every once in a while I thought maybe there is a knock. But I really could not tell.
During one of my rides I had another incident where the vehicle suddenly turned left on it's own. Shortly there after it felt like the 4wd system went into 4 low. A whine started in the rear that progressively got louder. When I dropped it off asked the service manager to have both issues looked into. The diagnosis on the engine is no bottom end issues, it just needs the manifold bolts replaced. They plugged her in and ran a diagnosis, a sensor in the 4wd system was going bad causing the right front to get power. That was replaced and fixed the turning issue. The rear end sound is the differential locking up, they're not exactly sure why but stated the rear including the axles need to be replaced. They recommend a rebuilt unit from Jasper, roughly $4,500.00 installed. I did a little research and it appears the differential locking damaging the axels is a relatively common issue. It's not wear and tear. I had the Service Manager turn it into the warranty company, so far so good they have approved the work. |
| All times are GMT -8. The time now is 01:16 PM. |
