I crack me up. |
F1 cars use technology like this right now. Energy is stored electronically.
Audi is introducing a turbo that is electronically pre-spooled to eliminate lag. Which is probably a simpler solution to this issue.
Just get some duct tape and a leaf blower. done.
http://forums.pelicanparts.com/uploa...1431624694.jpg |
Wouldn't a supercharger be more straightforward and efficient than running a similar compressor into a storage/release system?
I remember Don Garlits tried a compressed air reservoir in place of a belt driven supercharger. Must not have worked!
Wow! Can't sneak any funny stuff past you guys! You must be great fun at parties. |
Laddie? |
My boss is working on bringing that system in the article to market. |
Not the same thing....but France had an air-powered car a few decades ago:
BBC NEWS | Europe | France to unveil air-powered car All pressure between the butterfly and valves are dependent on use. |
He was a partner at NOS, and he doesn't like N2O now. It is too unstable- it will actually detonate (decompose) on its own under pressure, and it is not a repeatable thing cycle to cycle so it is really hard on engines. The compressed air is a smooth burn, much better for time between overhauls. |
Overall the car is less efficient, it's also heavier now. Next, you can't rely on the compressed air, so the car needs to have 'adequate' power without the aid of the compressed air. The compressor would be empty if you needed the extra power twice in quick succession. So now you are looking at 'fun' power, not base power. I don't see it. |
stored boost has been done successfully with a ducati twin setup so that one cylinder acts as a supercharger. boost is stored in a high pressure tank to assist with acceleration from a stop. i found a full write up on the project a couple of years back. if interested, i'll try to find it again.
| All times are GMT -8. The time now is 05:39 AM. |
